04-22-2007, 07:08 AM | #1 |
Newbie Join Date: May 2006 Location: tennessee
| stampede trans
would crazy glue work to lock the stampede tranny
04-22-2007, 09:55 AM | #2 |
Rock Crawler Join Date: Jun 2005 Location: Safety Harbor
Doubt it.Use JB weld,its much stronger.
04-22-2007, 09:57 AM | #3 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
04-22-2007, 11:31 AM | #4 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
wouldn't trust it for too long. use JB weld.
04-22-2007, 12:23 PM | #5 |
Quarry Creeper Join Date: Aug 2006 Location: NORTH TEXAS
ca and baking soda works great!
04-22-2007, 12:30 PM | #6 |
04-22-2007, 12:46 PM | #7 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
neg on crazy glue to brittle, JBWeld
04-22-2007, 03:45 PM | #8 |
Don't use any of it...just use the "spacer" mod to pull the other 2 outer planet gears upward into the sun gear like the other 2 planet gears. No need for any type of goooo |
04-22-2007, 04:43 PM | #9 |
04-22-2007, 07:42 PM | #10 |
Pebble Pounder Join Date: Jul 2006 Location: Superior wi
I did similar to offroader buy i left all the planetary gears in and used a couple washers cut down between the gears to lock the diff and mine works great no hassle nor mess of gooo
04-22-2007, 08:56 PM | #11 | |
For Sthamby: The reason this works is...the tranny has the 4 planetary gears around the center sun gear. When you assemble the tranny as per the instructions, you end up with 2 of the planetaries that do not come in contact with the sun gear. This is what makes it have the "differential" action...which is what we DON'T want. By adding a spacer below those 2 planetaries that when dropped in, sit down the lowest, you make it so that all 4 of the planetary gears are now in contact with the central sun gear at all times. I found that some plain 'ol 3mm nuts are just the right thickness and inside diameter to fit over the planetary gear pin/shaft. No more differential. Nice thing about this is that now you have no mess inside your tranny, so now parts are easy to fix if need be, or if you ever want to go back to an unlocked tranny, you can by simply removing those 3mm nut spacers. | |
04-22-2007, 10:04 PM | #12 |
Newbie Join Date: Mar 2007 Location: Finland
I used Würth super glue gel on all differentials. Works great, cant even open those even if I want. |
04-23-2007, 08:58 AM | #13 |
Rock Crawler Join Date: Jun 2006 Location: Santa Rosa
i want to try the washer technique on my other pede tranny, but for my first crawler, i used Gorilla Glue, i doubt it will come undone, it has been locked good for about 4 or 5 months.
04-24-2007, 10:02 AM | #14 |
thanks guys
