05-05-2007, 12:21 PM | #1 |
Newbie Join Date: May 2007 Location: UK Essex (The Rock)
| newbie to crawling
Hi to all , i started watching the rc crawlers on u-tube and throught i'd buy one, so i brought a wheelie king 2wd £149.99 which i throught was quite a bargin, i also brought the 4x4 conversion kit £80.00 and a Matrix Pro Lathe Motor 65T single £29.99. so you can gess what i'm up to at the mo....
05-05-2007, 01:21 PM | #2 |
Quarry Creeper Join Date: Apr 2007 Location: .
building it? welcome
05-05-2007, 01:26 PM | #3 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
Welcome to RCC!!
05-05-2007, 02:04 PM | #4 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
hey i see your from the uk where abouts did you get your 4x4 conversion? was it from the uk?
05-06-2007, 06:29 AM | #5 | |
All are HPI racing parts, A431 - Diff case £3.49 A855 - Diff Final gear set (P1x38T/P1x13T) £4.99 86014 - Gear diff bevel gears(13T+10T) £5.99 85258 - Uni Centre Drive set mittlkardan set (montiert/Wheely king) £9.99 86813 - Drive shaft 6x82mm (2Pcs) £9.99 86810 - Gear Shaft 5x6x29mm £5.99 B030 - Ball Bearing 10x15x4mm (2pcs) £15.99 B022 - Ball Bearing 5x11x4mm (2pcs) £14.99 B022 - Ball Bearing " " " " " £14.99 hope this helps | |
