07-11-2007, 04:05 PM | #41 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
07-12-2007, 07:33 AM | #42 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
07-12-2007, 11:51 PM | #43 |
Rock Crawler Join Date: Jun 2006 Location: Wisconsin
Alright guys, thanks for the info. One more question, regarding these droop suspension crawlers. They run internal shock springs. Do the springs go on the piston end or the rod end of the shocks? |
07-13-2007, 06:56 AM | #44 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Not all of them run internal springs. I have two here that don't use springs. Those that do run internal springs install them so that they cause the shock to retract...putting the spiring under the piston. |
07-13-2007, 08:52 AM | #45 |
I see. So most times it's nothing more then the shear weight of the axles that cause the suspension to droop or articulate - like the rocks falling out from beneath them. There really isn't anything to force the axles down, unless the crawler has independent front/rear speed controllers and you throttle the rear motor to bunch up the slack in the suspension? The belly must drag a lot when the suspension droops.
07-13-2007, 08:58 AM | #46 |
RCC Addict Join Date: Sep 2005 Location: ...Here & There
07-13-2007, 09:02 AM | #47 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
07-13-2007, 11:09 AM | #48 | |
| Quote: I am I right? | |
07-13-2007, 11:15 AM | #49 |
Adilynsdad too! Join Date: May 2004 Location: G ville
I only have one thing to say! My nitro Revo crawler with Nylint electronics is better than both! |
07-13-2007, 11:20 AM | #50 |
| Yes, that is correct.
07-13-2007, 12:10 PM | #51 |
07-13-2007, 12:50 PM | #52 |
RCC Addict Join Date: Feb 2007 Location: sweden
my opinion on the hustler (ok i have not tryed a stick chassie but just my opinion) is that i like it alot, had a coilover shock based rig before the hustler and i can do everything i did with the past rig, and it does better on sidehills, climbing steep rocks and overall i love the hustler, only thing i have on this rig is that dont break over sharp V shaper rocks, but it may be my foult or my setup. As for limiting straps u dont need to use zip ties, i used cable shoes and thin plastic coverd wire attached to the upper shock mounts and to the under link shock mount, works sooo much better now! a must do on a hustler imo, but as everyone says u have to play with the setup to suit ur driving style! Thx for the Hustler RCP Guys...crawling just got soo much more fun!
01-16-2009, 11:51 PM | #53 | |
Newbie Join Date: Dec 2008 Location: wausau
01-17-2009, 12:33 AM | #54 |
01-17-2009, 01:16 AM | #55 |
Rock Stacker Join Date: Nov 2004 Location: wildomar
I compete with a Hustler against the sticks, torsions, you name it at our socal comps. I have a bunch of money invested into my Hustler crawler (total so fare $3000). Even thought it's one of the most expensive crawlers out there it sucked at the begining because it was totally set up wrong and couldn't even go where 2.2s could go. But after a year playing with it and getting the correct combination this rig will take on any stick or torsion and be very competitive. The biggest difference I see in the hustler and the sticks is that it doesn't like to side hill very good and it has a little harder time going up steep walls compared to the sticks. But as fare as getting high centered it's not that big of a issue. You just need a little more speed to slid the belly over the rocks and let the tires pull it the rest of the way. But the BIGGEST differece is that the Hustler LOVES to crawl slowwww and will take on vertical drops and vertical walls with eas and being in controll the whole time. I love how my Hustler turned out and the only way I might try another chassis is if the Hustler 2 came out. Mine's the orange one |
01-17-2009, 01:57 PM | #56 |
So what exactly is the hot set-up with these? The chassis itself is pretty simple. As for tuning, you really only have shock length, shock oil, and shock position to play with. The rest seems to mostly be weight balancing, motors, gearing, and battery packs - nothing any different then any other crawler. From a set-up standpoint, it doesn't seem to complicated.
01-17-2009, 02:10 PM | #57 | |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
01-17-2009, 02:13 PM | #58 |
ohhhh nooo. there is ALOT more to play with than just elctronics. You really have to play with the 4link geometry and the length of the rig. Since the rigs are so long you have alot of axle steer and that's the biggest pain trying to figure how to get rid of axle steer. I would say the hottest set up is a 6 channel radio with (this is a must) channel mixxing and dual ESCs. |
01-17-2009, 02:20 PM | #59 |
I have been thinking on trying my Hustler with Revo shocks, sprung.
01-17-2009, 03:20 PM | #60 |
RCC Addict Join Date: Mar 2006 Location: Xxx
