TLT axle kits? hard to put together?? are these difficult to put together i canput together a leval 2 model without problems will these cause me any also this is my first obviously will i need any supplys ie screws screwdriver glue ect...??? thx guys AJ |
well with the directions its super easy, everything right thier you will prob need pliers (sp) and a screwdriver, the first set i built took like 15 mins. |
A phillips screwdriver and needle nose pliers is most of whats needed to put together Tlt axles. You're going to want some JB weld to lock the differential with, and some grease to grease the gears, bushing/bearings with. Lube any moving parts. |
