Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Charging 2/3A cell batteries
Old 08-12-2007, 12:55 AM   #1
Default Charging 2/3A cell batteries
I have 2 new 2/3A packs, one has 4 cells and the other has 6 cells . How long do I need to charge each pack?. I for got to ask when I got them.
drumbeater is offline   Reply With Quote
Old 08-12-2007, 08:00 AM   #2
The number of cells won't matter, but the time is determined by the chargeing speed and total capacity required by the pack.
Example might be a 1200 mah pack being charged at 1.2 amps will recieve 1200 mah in an hour. at .6 amps it'll rx the same 1200 mah in 2 hrs.
floogldood is offline   Reply With Quote
Old 08-12-2007, 08:36 AM   #3
FrankyRizzo's Avatar
Do you have a peak charger??
It should automatically charge it. Just set it to 1.5-2 amps.
FrankyRizzo is offline   Reply With Quote
Old 08-12-2007, 10:39 AM   #4
Not here, I guess I should get another one so I can have a good charger at both houses.
Old 08-12-2007, 08:57 PM   #5
I have an extra one if you need it.
