Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: 350 buget what to make scale crawler
Old 08-20-2007, 04:30 PM   #1
Default 350 buget what to make scale crawler
anyone have any ideas on a scale crawler that i could build. budget = 350 - 360 plzz help thanx. 2.2 scale
SaVaGe MaN SS is offline   Reply With Quote
Old 08-20-2007, 08:37 PM   #2
tlt costum and cheap electronics
hiliftcrawler is offline   Reply With Quote
Old 08-20-2007, 08:48 PM   #3
teamtom's Avatar
Scale crawlers are being debated as being the most expensive to build. Even the TLT 2.2 comp rig starts at around $500 and that's considered the cheapest. Best bet might be to start scale (Ford HiLift) or start crawler (AX-10) then start turning one into the other as your budget allows.
teamtom is offline   Reply With Quote
Old 08-23-2007, 08:20 AM   #4
Just a thought. I think if you got a WK and a body for a MGT/TNX (which is wider than a standard lexan body) Then do some link lengthening with some longer drive shafts.
madhatter is offline   Reply With Quote
Old 08-23-2007, 12:36 PM   #5
K_B
It can be done. Mine cost me under $400 if you substitute standard electronics and standard wheels. But I did buy EVERYTHING second-hand.
Typical TJ Scaler
madhatter is probably on to something. If it were me, I'd ditch the stock tranny and chassis in favor of a stampede or stealth tranny and a scale chassis like a K2 series or MFM Racing chassis. Including the price for new suspension links, you should be in the $350-360 range.
K_B is offline   Reply With Quote
Old 08-24-2007, 09:46 PM   #6
Build it from scratch. I build a my chassis from Ace Hardware tubed steel for less than $10. Get some misc. items off Ebay and your set.
kennebell50 is offline   Reply With Quote
