Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: WK gear cover ??
Old 08-23-2007, 01:21 PM   #1
Default WK gear cover ??
Is a gear cover necessary?I don't want to get dust in the spur and pinion, but I want to run a 96 tooth spur.If not I don't think a 93 will mesh with a 15 t pinion. I tried. Even shaved tranny a bit and it still won't fit. THoughts?
solomon7 is offline   Reply With Quote
Old 08-23-2007, 01:47 PM   #2
ΜΟΛΩΝ ΛΑΒΕ
chip cross's Avatar
trash it
chip cross is offline   Reply With Quote
Old 08-23-2007, 02:01 PM   #3
Well that's not very reassuring lol! There has to be another option. I don't want rocks chewing up the spur. That is however a last resort.
Old 08-23-2007, 02:43 PM   #4
I took mine off about 2 weeks ago after re-gearing and havnt had a problem at all.
Wetbox is offline   Reply With Quote
Old 08-23-2007, 03:21 PM   #5
It's pretty dusty where I play, so I am still a bit worried about junk getting in the gears. What about grinding away some of the gear cover? Son't know if that will work and I don't like the idea of no going back mods, but has anyone tried this?
Old 08-23-2007, 08:25 PM   #6
Ground dowm a bit on the inside of the cover and it fits like a glove! Thanks all!
Old 08-24-2007, 12:57 AM   #7
I've had mine off for quite a while now and haven't had any problems...and I like throwing roosts..
joemomma95 is offline   Reply With Quote
Old 08-24-2007, 06:09 AM   #8
mine has been off since day one,with no issues!
WOODS is offline   Reply With Quote
Old 08-24-2007, 02:05 PM   #9
Well mine fits now so I'm gonna keep it on, added piece of mind and all that
Old 08-24-2007, 04:09 PM   #10
Mines off. been a while too. I like looking at the gear spinning....Kinda like an open primary on a chopper. Heh heh.
sickfab is offline   Reply With Quote
Old 08-26-2007, 10:45 PM   #11
Mine's been off since June, haven't had a problem yet, other than trying to fit the the gear cover over the 96t spur gear...........
BJoe is offline   Reply With Quote
Old 08-27-2007, 12:59 AM   #12
Dremel ,sanding whee,l and a patient steady hand.
