Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: what size are my nuts
Old 08-23-2007, 07:53 PM   #1
Default what size are my nuts
for my tlt
I need to order some more locknuts but there are too many sizes to choose from.
Thanks
TxCruzr is offline   Reply With Quote
Old 08-23-2007, 07:53 PM   #2
TLTCrawlin's Avatar
4mm or 5mm
Im pointing at 4mm!
TLTCrawlin is offline   Reply With Quote
Old 08-23-2007, 07:56 PM   #3
Team *
62PYRO's Avatar
If you're talking about wheel nuts then,4mm.Most of the others are 3mm.
Pat
62PYRO is offline   Reply With Quote
Old 08-23-2007, 08:15 PM   #4
i guess i should have specified der....like the nuts that fit the 100+ screws the kit comes with. The same size screws that hold the axle case together and what not.
Old 08-23-2007, 08:16 PM   #5
2006 2.2 National Champ
BENDER's Avatar
The bulk of the stock TLT hardware is 3mm.
BENDER is offline   Reply With Quote
