| | #1 |
| Newbie Join Date: Aug 2007 Location: USA
| Where do you guys find your 1.9 tires and rims? I seen a thing or 2 in here about guys taking 2.2's a cutting them to size. I just bought a new set of Tamiya F-350 Hi Lift axles and driveshafts. What other things will I need that are for this axles? I know I what to be using 1.9 inch tires. I'm going to be building the frame out of alum. and want as many parts to be there from the start as possible. Sorry for the noob. questions. Gotta start somewhere right? |
| Sponsored Links | |
| | #2 |
| RCC Addict ![]() Join Date: May 2006 Location: Roseville
| Let me be the gentle one to tell you that the Search button will get you what you want. Probably the fastest place to find your 1.9 stuff is Tower. If you are into supporting the website, check out the vendors section here. RC4WD, The Crawler Store, RCP Crawlers...they all have 1.9 stuff. |
| | #3 |
| RCC Addict Join Date: Aug 2005 Location: VARCOR
| To continue your Hi-Lift theme.....................Hi-Lift wheels and tires would be your best 1.9 bet. |
| | #4 | ||
I was checking out towerhobbies and couldn't find anything??? Maybe my computer shows me what it wants to. Quote:
I've give towerhobbies another try and see if I can turn anything up. | ||
| | #5 |
| Wishing I was Crawling ![]() Join Date: Feb 2007 Location: Missouri Boot-Heel
| 1.9 tires: high lift, bfg, mud-slingers, trail doctors, fly wheels, or cut and shut 2.2's, 1.9 wheels: any touring car wheel will work, stock car, high lift, hpi vintage are a few... theres your choices, cause im not an a$$ and flame you for not using the search button...good luck and post up those pics... |
| | #6 | |
you're going to have to wait a month or two before the pictures show up. I guess I'll try some more with the search. | |
| | #7 |
| Rock Crawler Join Date: Apr 2006 Location: Eau Claire
| you need to click advanced search under the type box, then type what you want. the lower right side lets you pick where....... it weeds out a lot of non related stuff.....(just trying to help) good luck on your build, |
| Thread Tools | |
| Display Modes | |
