Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Bend my clod tie rod?
Old 08-28-2007, 06:55 AM   #1
Default Bend my clod tie rod?
I have been looking around here for a while and have a question. I have a clod with CVD's and jp's knuckles. I see other much more experienced guys running steering in the front with CVD's. Here's my question, a lot of those guys have a straight tie rod that connects the 2 knuckles to each other but if I try to do that, my link hits the front of the case before I get maximum throw. What am I missing?
Example:
Black
post #93
It was the first I could find.
enricopallazo is offline   Reply With Quote
Old 08-28-2007, 09:07 AM   #2
You should post a picture of what you have there; to make things more clear.
Renslipevol is offline   Reply With Quote
Old 08-28-2007, 01:27 PM   #3
j0e
is something mounted wrong?
my clods gone through more steering options than i can remeber,
but ive never hit the with front steering rod.
j0e is online now   Reply With Quote
Old 08-28-2007, 02:32 PM   #4
This is how mine is setup
You can see at full throw, the links would contact the case if not for the bends in both the tie rod and drag link
Here is where I first started grinding before the CVD's arrived, then I realized that grinding would not be enough
Another shot...
