Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: 4 wheel steering
Old 08-28-2007, 05:42 PM   #1
Default 4 wheel steering
how do you mod a tq3 for rear steer??
is this even possible??
if so can you direct me to a link or site that can explain??
thanks
skoooter is offline   Reply With Quote
Old 08-28-2007, 06:07 PM   #2
teamtom's Avatar
No offense, but try searching, and go back a ways since there are a lot of threads on different versions of this. Also there is a sticky of this at the top of the page in this forum...
teamtom is offline   Reply With Quote
Old 08-28-2007, 09:11 PM   #3
i saw it, i was hoping for a little more direct , possibly step by step instructions.. not a ridiculously upgraded version.
(though it is very cool)..
Old 08-30-2007, 02:40 PM   #4
here you go bud, to easy..
CLICK_HERE_CLICK_HERE
crawls2thewalls is offline   Reply With Quote
Old 08-31-2007, 12:22 AM   #5
I just modded my TQ3, so I have the bookmarks still. Here is the best/easiest way I found:
TQ3 mod + Radio Shack
It uses a potentiometer instead of a 3 position switch. This way you get proportional rear steer, instead of just full lock left and right. I also found a nice knob at Radio Shack that bolted right on.
Make sure the wire soldered to the middle tab on the stock switch is soldered to the middle tab on the potentiometer. Then solder the other two wires onto the remaining tabs. The outer wires can go on either side, only the middle has to stay in the same spot.
Clod_Master is offline   Reply With Quote
Old 08-31-2007, 06:58 AM   #6
I'm Dracula, Bitch.
JeremyH's Avatar
Here you go:
http://www.tcscrawlers.com/product.p...cat=116&page=1
All the parts you need with step by step instructions.
JeremyH is offline   Reply With Quote
