Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Got an idea but need input...
Old 08-29-2007, 02:46 PM   #1
Default Got an idea but need input...
Im probably going to be buying an AX10 but on the side I want to build a crawler out of my mini lst. Has anyone attempted this and can it be done? I would build a custom chassis out of aluminum but it would take me awhile seeing as I only have a dremel tool and a bunch of files....I need input and ideas from you guys since you know more about this stuff than i do.
SynisterUrge is offline   Reply With Quote
Old 08-29-2007, 03:25 PM   #2
read my post in here http://www.rccrawler.com/forum/showt...332#post828332
aggressivellc is offline   Reply With Quote
Old 08-29-2007, 03:31 PM   #3
Ok, what if i wanted to build a custom but a 1/18th custom? What would be a good material to build the chassis out of?
Old 08-29-2007, 03:40 PM   #4
aluminum or lexan is probably your best bet
Old 08-29-2007, 05:35 PM   #5
Default When/Where is the next Colorado event?
Can you tell me when and where the next Colorado rc crawling event is?
PIMPNROCKS is offline   Reply With Quote
