09-03-2007, 01:18 PM | #1 |
I joined the Band! Join Date: Aug 2007 Location: Paso Robles
| RC Vocabulary
I was wondering if there has been anyone who has compiled a list of the acronyms and meanings of the words used in RC Crawling? I find it a little confusing to understand all that is being conveyed in some messages without the understanding of the acronyms. For example: I see the word Clod this and Clod that being applied to a lot of descriptions. Now I know what a dirt clod is, but I'm not sure how that applies to Rock Crawling. I thought that maybe it was a generational thing, with others being able to text message and all that, so I hope I'm not sounding too ignorant, or too old but I was just curious. I have a real interest in RC Rock Crawling so I'm trying to get the most out of the reasearch I'm doing. I would appreciate any insight. |
09-03-2007, 01:25 PM | #2 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
Clod = Tamiya clodbuster Wk = Wheely king cog = center of gravity just to name a few |
09-03-2007, 01:38 PM | #3 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
"Clod" refers to anything that has to do specifically with a tamiya clodbuster axle based rig. "WK" applies to HPI Wheely King based rigs. "Scorpion" or "AX10" refers to Axial AX-10 Scorpion based rigs. "COG" Center of gravity "GC" Ground Clarence "2.2" refers to any rig running a 2.2 sized wheel. Whether it be a comp rig, scaler, basher, etc. "1.9" same as 2.2, but with 1.9" wheels instead. These are generally scale looking vehicles, "Scaler". "Super" or "Unlimited" refers to you're larger sized comp rigs. Any thing else you are wondering about? |
09-03-2007, 01:45 PM | #4 |
Pebble Pounder Join Date: Dec 2005 Location: Parts Unknown (Eastern Sho, Maryland)
There are some threads on this but as times change, so do the acronyms. For instance, MM= motor mounts but can now also mean Mamba Max (esc) acronym dictionary needed Newbies and Acronyms |
09-03-2007, 01:56 PM | #5 |
Quarry Creeper Join Date: Jul 2007 Location: Kansas city
If you see one you don't understand you can always "search" it. With a little bit of reading I am usually able to figure it out
09-03-2007, 01:56 PM | #6 |
How about TLT? I see that a lot.
09-03-2007, 02:06 PM | #7 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
that's is a model made by tamiya (I think it means tiny little tamiya but not sure)
09-03-2007, 02:33 PM | #8 |
I think tlt stands for Tamiya little truck, bit I'm not 100% sure. TLT refers to any rig running TLT axles. Most of the time these will be your 2.2 and 1.9 crawlers (comp rigs and scalers). The TLT axles are the most popular axles out there. But now that the wheely king and axial ax-10 are out, the tlt has some good competition. The "TLT" has also been discontinued, so their parts are getting harder and harder to come by. |
09-03-2007, 11:25 PM | #9 |
Quarry Creeper Join Date: Aug 2006 Location: NORTH TEXAS
Maxx = Is any axles that are made out of a TRAXXAS T-MAXX or E-MAXX. OR when refuring to Maxx shafts, same trucks. SHAFTY = any truck that uses a central transmission and drive shafts going to the axles. 55T, 65T OR 75T = The number of winds in the motor. 8T, 9T OR 10T (small number and a "T") = is refuring to a pinion gear. PINION GEAR = This gear is the one on the shaft of the motor. SPUR GEAR = This is the gear that the pinion mates up with on the tranny (the BIG gear). LINKS = The rods that go from the chassis to the axles. TQ-3 = This is a transmitter made by TRAXXAS, it has 3 channels (ch1 steering, ch2 is throttle and ch3 can be used for other things such a DIG or 4WS). 4WS = is when you can steer with all 4 wheels , 4 WHEEL STEERING. DIG = Is being able to disengage the rear drive shaft from the trannys power and apply a BRAKE with the flip of a switch. |
09-04-2007, 12:57 AM | #10 | |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
being a fellow new member I appreciate this thread as I was wondering the same, but have figured some out on my own (not with searching). for example, "pede tranny" I have surmised to mean "stampede tranny" but I dont know that for sure...and I guess that comes from a stampede truck? | |
09-04-2007, 02:07 AM | #11 |
Yeah a you got it. a pede tranny comes with a stampede.
09-04-2007, 03:40 AM | #12 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
ESC = Electronic Speed Controller. BEC = Battery Elimination Circuit. This is a small current given by the ESC to power the servos. RX = Reciever. TX = Transmitter, or Texas. RX Pack = Another battery pack that is there purely to power the servos. XF = X-Factor, another type of truck from which the axles are used for crawling. Last edited by Tanis; 09-04-2007 at 01:11 PM. |
09-04-2007, 08:02 AM | #13 |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
center of gravity is just 'CG', not cog.
09-04-2007, 08:17 AM | #14 |
Quarry Creeper Join Date: Feb 2007 Location: Japan
09-04-2007, 10:31 AM | #15 |
Pebble Pounder Join Date: Jan 2007 Location: drunken Duncan B.C
Mah (on a battery) = milliamps per hour. How long a battery will run. usually around 1500 mAH
09-04-2007, 11:12 AM | #16 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
| I pulled alot of them together CRAWLER SLANG CG = center of gravity GC = Ground Clarence 55T, 65T OR 75T = The number of winds in the motor. PINION GEAR = This gear is the one on the shaft of the motor. SPUR GEAR = This is the gear that the pinion mates up with on the tranny (the BIG gear). 8T, 9T OR 10T (small number and a "T") = is refuring to a pinion gear. LINKS = The rods that go from the chassis to the axles. TQ-3 = This is a transmitter made by TRAXXAS, it has 3 channels (ch1 steering, ch2 is throttle and ch3 can be used for other things such a DIG or 4WS). 4WS = is when you can steer with all 4 wheels , 4 WHEEL STEERING. DIG = Is being able to disengage the rear drive shaft from the trannys power and apply a BRAKE with the flip of a switch.. ESC = Electronic Speed Controller. BEC = Battery Elimination Circuit. This is a small current given by the ESC to power the servos. RX = Reciever TX = Transmitter RX Pack = Another battery pack that is there purely to power the receiver. Mah (on a battery) = milliamps per hour. How long a battery will run. usually around 1500 mAH RTR = ready to run W/B = Wheel base TR2- Tekin Rebel 2 ESC BTA=Behind The Axle (steering linkage) TT= torque twist pede = short for Traxxas Spampede SR or Super Chicken = Novak Super Rooster TW = Track Width WB = Wheel Base 4WS = 4 Wheel Steer Clod = Tamiya Clodbuster based rig TLT = Tamiya little Truck based rig Maxx = Traxxas T-Maxx , S-Maxx or E-Maxx based rig Scorpion AX-10 = Axial based rig (there is a Scorpion made by Nylint also) WK = HPI Wheely King based rig PTI = PTI Goliath based rig TXT = Tamiya TXT based rig Shafty = shaft driven ( TLT , Maxx , AX-10 , WK , TXT , Twin Force & X-Factor to name a few) Lint or wally world crawler = Nylint based rigs 40s or 40 series = this speek of the rim size Maxx size or 3.2 = stock T-Mxx or E-Maxx size rim 2.2 = wheel size used on Comp rig or 2.2 scale rigs 1.9 = wheel size used on 1.9 scale rigs Modded = cut and shut , narrowed or reduced tires 1/6th or 1/18th = Nylint wheels/ tires . I hope this help people out . Last edited by Badd; 09-04-2007 at 01:33 PM. |
09-04-2007, 11:16 AM | #17 | |
Newbie Join Date: Aug 2007 Location: England
Some electric terms: Ah: Amps measured how many transfered in one hour Ir: Internal resistance, mainly for batteries 645 or 645mg: type of hi-torwue servo made my hitech used in crawling alot endbell: the back end of a motor, holds the brushes, springs and power wires BL: brushless motor 2.4: normally stands for a special type of radio frequency in which you needent change frequencies, radio does it for you. made by spektrum, futaba and nomadio to name the famous ones. | |
09-04-2007, 12:57 PM | #18 |
09-04-2007, 01:34 PM | #19 |
09-04-2007, 05:11 PM | #20 |
