| | #1 |
| Quarry Creeper Join Date: Sep 2007 Location: Carlisle
| how do you wire 2 motors to one esc. pics would be great thanks |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Mar 2007 Location: Baltimore
| | #3 |
| | #4 | |
| Rock Crawler Join Date: Mar 2006 Location: Auburn, WA
Some will try to tell you that wiring to one motor first is better, but if you use high quality wire, there is not enough resistance between them to make any noticable difference at all. | |
| | #5 |
| ~The Scale Shop~ ![]() Join Date: Apr 2006 Location: KILLEEN TX
| i run a perfectly symetrical Y harness. and have never had ANY clod stall..... |
| | #6 |
| Pebble Pounder Join Date: Nov 2005 Location: Back in MICHIGAN
| what i run is the parrallel wiring system on the motors, where both motors tie into the esc. what your seeing there is series. |
| | #7 |
| RCC Addict Join Date: Aug 2005 Location: VARCOR
| | #8 |
| ok my bad, its parallel but my parallel wiring is set up differently. |
| | #9 |
| Rock Crawler Join Date: May 2007 Location: lacey
| unfortunately for me, I have an traxxas EVX on mine:-( which has outputs for two motors, but a sucky speed control for crawlin'. As stated above, you have to wire them in parallel. |
| | #10 |
| Pebble Pounder Join Date: Nov 2007 Location: Louisville
| | #11 |
| | #12 |
| Its a beautiful day in the neighborhood...lol |
| | #13 |
| Newbie Join Date: Nov 2007 Location: calgary
| isnt wiring two motors in a single-motor specific ESC overkill. i tried to wire two integy 55 turns in a XL5 an it gets hot like crazy!! wouldnt that do the same to any other single motor ESC!! |
| | #14 |
| Quarry Creeper Join Date: May 2004 Location: delavan
| i run this same set up in my clod no problems with over heating i ran both motors together then spliced in my bullet connectors |
| | #15 |
| Rock Crawler Join Date: Feb 2007 Location: weather sucks ,mn
| super roosters can handle it .......back in the day i had a clodzilla 3 with 2 super rooster and 20 cells with 2 10 triples speed gems and talk about fast weeeeeeeeeeeeeeeee |
| | #16 |
| so whats a good or fair ESC that is built for one motor but can handle two motors with the parallel wiring? i really need to know. thanks guys |
| | #17 |
| Pebble Pounder Join Date: Sep 2007 Location: Northeast
| I have 2 55t's wired to a Moped V16r Bravo ESC, works fine. |
| Thread Tools | |
| Display Modes | |
