Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: RCP Ring & Pinion
Old 11-25-2007, 04:19 PM   #1
Default RCP Ring & Pinion
I didn't know if you should grease the RCP Ring and Pinion. I know the teeth are deeper cut, but it sure makes a lot of noise when mocked up. Grease or not grease... that is the question? Thanks
procraft98 is offline   Reply With Quote
Old 11-25-2007, 05:16 PM   #2
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
I lubed mine up and they quiet down after you run them a few times.
Stormin2u is offline   Reply With Quote
Old 11-25-2007, 05:21 PM   #3
How much? A lot or just around the teeth? I'm going to use white lithium.
Old 11-25-2007, 10:01 PM   #4
whatever!
MOCRAWLER's Avatar
i just smeared a thin coat on the ring gear while rotating it and it quieted down considerably.
MOCRAWLER is offline   Reply With Quote
Old 11-25-2007, 10:21 PM   #5
I just filled the depth of the teeth on both the ring and pinion with Tamiya Ceramic Grease and they're virtually quiet.
BGGruff is offline   Reply With Quote
Old 11-25-2007, 10:24 PM   #6
just put a small amount on and keep adding some until they quiet down.
newpinesap is offline   Reply With Quote
