Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: TLT Diff Locks??
Old 05-13-2005, 06:38 PM   #1
Default TLT Diff Locks??
Has anyone tried using Ofna's Diff-Lock or something similar?
http://www.ofna.com/acc-fluids.html
.... or is the concenus mostly JB-Weld, putty, hot-glue.... or something like that?
SantozRey is offline   Reply With Quote
Old 05-13-2005, 07:06 PM   #2
I use those in my 1/8 scale buggy. It slows down the diff action. it would not be a good solition in a TLT-1 because the diffs are not sealed.
CrawlerFreak is offline   Reply With Quote
Old 05-13-2005, 07:08 PM   #3
well the problem with oil is that most of the diffs' you'll see on this site are'nt sealed, so it tends to leak out in a short amount of time and make a mess.
mike is offline   Reply With Quote
Old 05-13-2005, 07:38 PM   #4
and it doesnt lock the diff either.
Bomb-ProofProducts is offline   Reply With Quote
Old 05-13-2005, 10:07 PM   #5
you can also use the pajero/touareg(sp?) g parts diff lockers. or you can move one of the spider gears to lock the diffs also. both of these methods do not require adhesives of any kind and are completely reversible.
fuzzhead is offline   Reply With Quote
Old 05-14-2005, 01:15 AM   #6
you got a link to those... "pajero/touareg(sp?) g parts diff lockers"
Old 05-14-2005, 01:17 AM   #7
If I could seal the axles would it work??
What if I used a heavy automotive gear oil?
Old 05-14-2005, 10:48 AM   #8
It is not going to lock the diff totally. I would just fill the diffs up with JBW thats what I did and it worked great. I don't really know about the automotive gear oil, I can't even drive yet. 2 more years .
Old 06-02-2006, 11:16 PM   #9
Is the JB weld a good choice in these metal diffs? I've had very good results in a Clod. Or is something else preferred?
Eagle-Mark is offline   Reply With Quote
Old 06-02-2006, 11:18 PM   #10
JB Weld seems to be the standard in locking Pede Trannies.
Mad Scientist is offline   Reply With Quote
Old 06-03-2006, 12:31 AM   #11
Using oil in these diffs really wouldnt acomplish anything. On a good crawler the diff doesnt spin fast enough to need oil. IF you sealed your axles you could use oil but not to any real benifit
xjman is offline   Reply With Quote
Old 06-03-2006, 01:29 AM   #12
Just having Fun Again
Red Rockcrawler's Avatar
just lock it with jb weld.
Red Rockcrawler is offline   Reply With Quote
Old 06-03-2006, 08:10 AM   #13
x2.
Crawlsalot is offline   Reply With Quote
Old 06-03-2006, 04:59 PM   #14
Instede of jb weld you can lock it with hot glue.
revoster is offline   Reply With Quote
Old 06-03-2006, 05:05 PM   #15
I have had bad luck with the hot glue. I just moved one of the spider gears inbetween the other two. It locks the diff and is reversable if I ever want to sell it.
tkruger is offline   Reply With Quote
