| | #1 |
| Newbie Join Date: Dec 2007 Location: Thailand
| Just got mine and find out that I got a set of super firm spring (blue ax30217) in my scorpion. Do you have the same set of spring as mine? I thought that they will give us a medium one. Any idea? |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
| You only get 4 blue firm springs with the kit. But they do offer super soft to super firm as an option |
| | #3 |
| Rock Stacker Join Date: Dec 2007 Location: toledo area
| I have the axial white's all around and seam good. I will be buying the next step softer to try out also. |
| | #4 |
| Quarry Creeper Join Date: Nov 2007 Location: Oregon
| I run the blues in the rear and greens in the front |
| | #5 |
| Newbie Join Date: Jul 2006 Location: Greenville
| Mine came with the blue. I've got the super-soft on the way to try out. |
| | #6 |
| Alot of guys run Axial whites (soft) and axial green (medium) in the rear with stock pistons and 30wt oil works pretty good |
| | #7 |
| Quarry Creeper Join Date: May 2007 Location: Seattle
| I spent Christmas trying springs. Personal preference plays some role in selection, but I also found the greens in the rear worked best. I tried whites up front, was okay, I tried Traxxas red springs and I liked that the best. I also limited the shock travel 10mm front/rear with inner spacers. Seems to work much better in general. |
| | #8 |
| thank to you all. I ordered white for the front and will use blue at the back for now. will see how it work. |
| | #9 |
| Quarry Creeper Join Date: Nov 2007 Location: southender
| i have the super firm blues in the rear and losi greens in the front.... |
| | #10 |
| Rock Crawler Join Date: Jul 2007 Location: Portland,OR
| Got the blues in back and hpi yellows up front. I like it but am waiting for the axials to get here and try a little firmer up front. |
| | #11 |
| Pebble Pounder Join Date: Nov 2007 Location: Sacramento
| I have been doing a bunch of searching, and some are running a firmer spring in the left rear to help with the dreaded torque twist. Any thoughts? |
| | #12 |
| C U S T O M P A I N T ![]() Join Date: Dec 2007 Location: Great Falls
| | #13 | |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
For very cheap you can try for yourself, or maybe someone that has tried it will chime in. I use all Axial green coded springs on mine, softer than the kit supplied, and no preload spacers. Put the limiter on the inside, and I used fuel tubing of some length on the outside, could actually be the same size as the kit's limiter, I don't like a lot of flex. But the real trick is the upper links on the TCS Boomerang. Using the same spring rate on both sides makes for a well balanced truck. | |
| | #14 | |
| | #15 |
| | #16 |
| Quarry Creeper Join Date: Aug 2007 Location: Winnemucca
| thanks eepee I think I'll try this too |
| | #17 |
| Nope, nothing funny happens. Nothing noticeable anyways. |
| | #18 |
| MadDogRC LLC ![]() Join Date: Mar 2007 Location: Petaluma
| I'm running the axial red springs all around with 60 wt oil in all excet the left rear. I have 100 wt in the left rear with a med spacerto combat torque twist. I also have the boomerang and spacer in the shock bodys to lower the CoG. Works well for me. |
| Thread Tools | |
| Display Modes | |
