Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: wk question
Old 12-27-2007, 04:17 PM   #1
Default wk question
my rear axle makes a grinding noise and will not spin when i try to go up steep inclines. my axles are locked and so is the trani
i was wondering if anyone knew anything about this or how to fix it
4x4boy is online now   Reply With Quote
Old 12-27-2007, 04:23 PM   #2
are you sure its not the slipper.
bigblazerboy is offline   Reply With Quote
Old 12-27-2007, 04:31 PM   #3
there is no slipper i have the axle locker kit from thecrawlerstore
its been doing this for a while
ive opened up the axle a few times to see if i could see anything wrong
Old 12-28-2007, 02:06 PM   #4
the slipper is in the tranny. I would check the pinnion angle when you go up hills. the pinnion is were the drive shaft goes into the diff in the rear. when you start to go up hill, look at the drive shaft, if the angle from it, to the diff is to dramatic, it can lock up.
gearmonkey23 is offline   Reply With Quote
Old 12-28-2007, 02:46 PM   #5
It sounds as if your differential is not shimmed properly, and the diff gears are slipping. You'll need a complete diff kit, and that should come with the shims, bearings, everything.
The WK's are notorious for this problem.
JavelinSST390 is offline   Reply With Quote
Old 12-28-2007, 04:05 PM   #6
...he said the diff is locked..
Old 12-28-2007, 04:20 PM   #7
What I meant is the ring and pinion are probably what's grinding.
Old 12-29-2007, 12:22 PM   #8
ya my diff gear is chipped i took it out again and looked at it
