| | #1 |
| Newbie Join Date: Dec 2007 Location: High Point
| i have a wheely king modified up pretty nicley and running a 55 turn integy motor with the stock esc, i have a 6 cell 4200 intellect stick pack ...i can put the car against a wall and it will not climb it at all....i can climb it at a angle but if i try to climb my wall straight ahead it just sits there as if the battery is dead or to much power is trying to go through the ESC or somthing ?..i figured if i give it all the gas it has it should spin up it but instead it will move like 1" up the wall then cut off..ive tried 2 different motors so i know the motor isnt the problem |
| Sponsored Links | |
| | #2 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| It could very well be the ESC. It takes a lot of grunt to go straight up a wall since the rear tires are trying to push forward at a faster rate than the fronts climb. |
| | #3 |
| would a ESC give it more grunt though ? i know if it was nitro id lean that baby down and hammer it, but its hard to get that out of electric hahaha |
| | #4 |
| Rock Stacker Join Date: Jan 2007 Location: Spain -> Granada
| What pinion and spur gear are using?? If you have a large reduction, the crawler can't climb the wall because the motor not have enought torque |
| | #5 |
| 15/96 |
| | #6 |
| I don't the axle's reduction, but if it is similar with TLT axles and pede tranny, i think, that this reduction is a bit longer. I use in my TLT 14/86 and 65T and if the situation required a lot of torque the motor can't move the wheels Last edited by feuerradder; 12-29-2007 at 02:55 AM. |
| | #7 |
| Quarry Creeper Join Date: Oct 2006 Location: kansas city
| How long have you been using the 55 turn? Maybe its time for a rebuild. It really doesn't take long for a motor to need its com turned and new brushes. Check how long the brush is compared to a new motor. If its quite a bit shorter you have your culprit. Randy |
| | #8 |
| ive tried 2 other motors..myn is a 55 turn and ive tried the novak 55 and a integy 65 and niether seemed to help it out...if i just go out and buy a cheao duratrax foaward/reverse speed control will that give me any more power or runtime ? |
| | #9 |
| Quarry Creeper Join Date: Jul 2007 Location: south jersey
| the wheelie king tranny has a slipper clutch in it , you have to lock it ,it makes a big difference, |
| | #10 |
| http://www.gsrcrc.com/showthread.php?t=379 post #13 my friend locked his and it works much better Last edited by tat2INDY; 12-29-2007 at 09:25 AM. |
| | #11 |
| alright, ill do a search for that incase you know how i could do it ? |
| | #12 |
| Pebble Pounder Join Date: Apr 2007 Location: san diego
| my ax10 will do that with ease mamba 25 b9 bl 1500 x8 x 2/3 saddle pk spectrum 3 it flips over w/speed and lands upright also i have a couple of wheely king setups that will climb straight up and flip upsidedown but not as fast wx axles r2 trans stock wk esc/transmiter/rx 3600 stick pk sub c 55t wk axles wk trans locked stock wk esc/transmiter/rx 3800 stick pk sub c 55t ckeck everything batt voltage,the trans clicks when slipping, connections good luck Last edited by 3Samudra; 12-29-2007 at 03:36 PM. |
| | #13 |
| MWRCA'er ![]() Join Date: Apr 2004 Location: Byron, IL
| You really need to be more specific. Does the truck just drive to the wall and then go silent? Does the motor make a straining noise? Do you hear a POP POP POP when you hit the wall? |
| Thread Tools | |
| Display Modes | |
