Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: My run time?
Old 12-29-2007, 12:34 AM   #1
I joined the Band!
Default My run time?
Just curious if anyone could tell me what run times Im looking at in my Ax-10. Im running the TCS split 6 cell axle packs (1500mah batteries) with a 55T integy motor. Anyone running a similar setup to give me a good estimation of run time?
Knoc is offline   Reply With Quote
Old 12-29-2007, 01:25 AM   #2
I got about 45 min of crawling out of the same set up !
liveforocks is offline   Reply With Quote
Old 12-29-2007, 02:38 PM   #3
Mriswith's Avatar
about 45 minutes on the same pack. I'm running a 65T integy with stock gearing on Moabs.
Mriswith is offline   Reply With Quote
Old 12-30-2007, 08:45 PM   #4
xgerstandtx's Avatar
actually timed mine today
ax10 stock gearing 7oz each front wheel 3oz each rear wheel 45t integy
6cell elite 1500 battery
47 minutes of good crawling time at red rocks
xgerstandtx is online now   Reply With Quote
Old 12-30-2007, 09:40 PM   #5
after about 30 mins, I start to notice a reduce in wheel speed, but there is plenty of bottom end torque for another five or ten mins.
mysharona is offline   Reply With Quote
