08-22-2009, 01:37 AM | #101 |
Quarry Creeper Join Date: Jul 2008 Location: peoria
yes it would work just make custom side plates/shock mounts and get a solid axle might even be able to use the stock tranny
08-26-2009, 09:55 AM | #102 |
Newbie Join Date: Feb 2009 Location: Big Rapids
just picked up a body, a set of MSR9 shocks and some thin sheet aluminum last night. A rolling chassis should be on the way :-P I'm thinking of nixing the sheet sides and making up a tube rear for it though....your thoughts? Edit: what wheels are those on there. the issue im having is finding a set of four matching wheels that work with the 12mm hex of the king axles, and the dual bearings of the T4 front. also, did anyone ever find out what the gearing was on these things? or what its speed range was? Do the original posters/ builders even look at this thread anymore :( Last edited by PCK_4xCustoms; 08-26-2009 at 12:34 PM. |
08-26-2009, 10:51 AM | #103 |
08-26-2009, 04:18 PM | #104 |
"69 spur 39 pinion on a veileon and a 3s 25c lipo you can only run this gearing on a low Kv motor none of the castles will run this" thats what he told me over youtube and he uses hpi wheels they come with axle mount and 12mm hex
08-26-2009, 05:52 PM | #105 |
so a 4600 sidewinder wouldnt do too well eh? I really cant afford a MM or Velenion right now. maybe the V if I just said eff it and dropped the cash. |
08-26-2009, 10:02 PM | #106 |
you could just get a smaller pinion or sell just the motor and buy the vxl motor for 50 bucks the sidewinder is really good
09-09-2009, 03:43 PM | #107 |
so um yeah...what driveshaft is that? I dont know what shaft would work between the ax10 trans output yoke and the hpi axle yoke. my ax10 locked trans is in the mail |
09-09-2009, 04:14 PM | #108 |
i think he drilled it out
10-31-2009, 08:53 AM | #109 | |
Pebble Pounder Join Date: Feb 2008 Location: here
To power mine I used a 5700kV motor with a 27 tooth pinion. I'm thinking of switching out the AX-10 transmission with a pede tranny though. I built mine from an MT2 chassis. If I can get some pics later today I will post. | |
12-08-2009, 10:45 AM | #110 |
Pebble Pounder Join Date: May 2008 Location: El Monte
WE NEED UPDATES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ! haha......v ery nice work almost beats the real thing in super awsomeness |
01-09-2010, 09:30 AM | #111 |
Newbie Join Date: Jan 2010 Location: Fort Worth
Def need updates, these are sweet
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/non-crawler-rcs/146375-scale-performance-trophy-trucks.html | ||||
Scale trophy Truck - R/C Tech Forums | This thread | Refback | 10-05-2011 06:32 PM | |
Trophy Truck RC | This thread | Refback | 10-04-2011 06:29 PM |
