Go Back   RCCrawler.com Bulletin Board > Miscellaneous > Non Crawler RC's
Thread: Harley's Low Rider
Old 12-07-2008, 01:21 PM   #1
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Default Harley's Low Rider
Well Venom-Crawler inspired me last night with his Low-Lux project, so I got to building.
I had all this stuff laying around the house so I figured I might as well throw it together to get me going.
Here is the build list so far:
  • X-Trail
  • Narrowed TLT Axles for extreme tuck-age
  • Axial Trans with aluminum case
  • Prototype VF Dig (spun around so I can run 2wd or lock up the front for burnouts )
  • Traxxas VXL system I have (as soon as Brandon sends it back )
  • 2s Lipo
  • Tour Car wheels with rubber tires
  • 4PK controling it all, and I might have to use the 4th channel to do some servo actuated suspension
Here is the start
So now I have to decide on a body, I may go with the F-350 but a Yota may still happen as well.....Thoughts?
Harley is offline   Reply With Quote
Old 12-07-2008, 01:24 PM   #2
I've always wanted to do something like this, looks good.
grizz is offline   Reply With Quote
Old 12-07-2008, 01:34 PM   #3
Default cool
what are you doing about suspension??
maybe 4 servos for independent suspension in all for corners kinda like hydros, i've had this idea for a while now but since im not doing it anytime soon i'll share with you cuase your on a good start.
long aluminum servo arms with touring car shocks at the end conected to the axle, and then you just plai with springs and oil, 6 channel radio also.
rusty_rail is offline   Reply With Quote
Old 12-07-2008, 01:43 PM   #4
Throwing Grenades
Harley's Avatar
I have thought about the hydro thing before too, I think I may just do a raise and lower type deal though. I want to run the dig so I can do burnouts and that is going to take up a channel. I guess I could hit up Futaba for another radio but I don't need to press my luck
Old 12-07-2008, 01:44 PM   #5
Looks great Harley!
I am also thinking of running a R2D II backwards to get 2WD/4WD and lock the axle for burnouts, but on my upcoming Dakar LR3. And the servo suspension would be cool also. I might think about that, seeing as the real LR3's can raise or lower the suspension.
Can't wait to see more.
AeroSynch is offline   Reply With Quote
Old 12-07-2008, 01:45 PM   #6
Throwing Grenades
Harley's Avatar
I need to make links still but I am going to wait until I choose the body and it gets here. Right now it is sitting at 11 3/4 which is obviously way too long. I might be able to use the rear shock hoops as a C-notch and put some draggin block out the back
The outside to outside dimension is 7" with wide hexes. I can go narrower by about 1/4".
Old 12-07-2008, 03:53 PM   #7
If you cut out the frame below where the shock hoop is, you can tuck the axle into the frame more, like c-notching the real thing.
RaleighRCer is offline   Reply With Quote
Old 12-07-2008, 03:54 PM   #8
Throwing Grenades
Harley's Avatar
Old 12-07-2008, 04:10 PM   #9
Throwing Grenades
Harley's Avatar
I just ordered the body from RPP, going with the F-350. Knowing RPP I will have it Tuesday
Now I need to learn how to do styrene work and do something special with it
Old 12-07-2008, 05:07 PM   #10
a 4x4 lowered truck? jk looking good man glad that i inspired you. you could always use a lexan body like the 72 chevy body if you cant tuck those under that ford body.
venom-crawler is offline   Reply With Quote
Old 12-07-2008, 05:20 PM   #11
I'm a stupid C U N T!
slobin3d's Avatar
I like the Idea of a line lock maybe look into a 4wd touring car front end for a indy front?
a bagged clod bodied c-10 would be sweet,
for the auto lowering, I was thinking about a cantilever setup on all 4, front and rear tied together and either a separate servo on either side or a find a way to link them in the center so you only need the 1..... now I'm thinking of all the things I would try, crap.....
slobin3d is offline   Reply With Quote
Old 12-07-2008, 05:40 PM   #12
Throwing Grenades
Harley's Avatar
I am definitely planning on doing a cantilever setup but I am thinking of maybe only doing a rear setup, tail dragger.
I am not sure about swapping out the front yet, definitely a thought.
Old 12-07-2008, 08:52 PM   #13
IF you want the suspension to drop you can still mount some shocks vertically, just use an arm on the shock towers attached to a servo to change the "height" of the shock mount without losing a spring suspension.
2JSC is offline   Reply With Quote
Old 12-07-2008, 09:15 PM   #14
Thats actually a really good idea, as long as you can get a solid mount. Why not use the new Tamiya Tundra body for this build?
Rudukai13 is offline   Reply With Quote
Old 12-07-2008, 09:23 PM   #15
Throwing Grenades
Harley's Avatar
That is arm is what we were referring to as a cantilever. So, yup that is the plan
Old 12-07-2008, 09:24 PM   #16
Throwing Grenades
Harley's Avatar
It is not available yet, as far as I know. This isn't a super crazy build. Just something that will be easy to do and fun to drive. I don't feel like waiting.
Old 12-07-2008, 09:25 PM   #17
Ok - I thought that's what you were talking about, but my brain is too tired to put it all together.
I like Rudukai13 idea... Tundra.
Old 12-07-2008, 11:22 PM   #18
Are you giung to leave the the trans locked, or are you going to swap a ball diff so it's more of an AWD instead of a locked 4wd?
BJoe is online now   Reply With Quote
Old 12-07-2008, 11:34 PM   #19
Throwing Grenades
Harley's Avatar
Nope, locked with locked diffs and big power. I want it to drive like a drifter, I have always wanted a drifter
Old 12-07-2008, 11:37 PM   #20
Off-Topic: What camera are you using for your pics?
