| | #1 |
| Pebble Pounder Join Date: Apr 2008 Location: greenville
| I just got a slash and tossed a mamba and 6900kv motor in it, and i was wondering if anyone else has tried this setup and what gearing you ran. right now im stick with 6 and 7 cell nimh packs. |
| Sponsored Links | |
| | #2 |
| I wanna be Dave Join Date: May 2005 Location: Anchorage, Alaska
| Check this thread out. There's a bunch of discussion on gearing. Got My Slash Today!!! Do you have a temp gun? I usually determine gearing through motor temp. I try to keep the temperature around 130-150 degrees. If it creeps up near 150, I usually go down a few teeth to get the temp down. |
| | #3 |
| Quarry Creeper Join Date: Aug 2005 Location: newport
| 6900 I think I'd start with a 15 tooth pinion temp gun ($20.00) will help a lot, you don't want to see abve 160 if you can help it. I personally try to stay below 130 |
| | #4 |
| I wanna be Dave ![]() Join Date: Dec 2005 Location: Hawthorne, Florida
| Gear it as low as you can. Lot of amp draw with those 6900 and 7700's. The Slash is a porker so expect temps to be high on the motor and esc. |
| | #5 |
| yeah thats the only thing i dont like it about the high kv motor, but beggers can't be choosers but thanks for the help. |
| | #6 |
| Whycome U no have tattoo? ![]() Join Date: Feb 2008 Location: Tekin, ID
| As long as you check your motor every few minutes and it doesn't get up above 175*-180* you're good to go. My Slash is equipped with a 3700kV motor, its decently fast for how I use it and the motor temps at about 170* after a full pack (about twenty minutes) of constant redlining it! |
| | #7 |
| Quarry Creeper Join Date: Feb 2008 Location: Boise
| Also check out www.rcgearing.com, quite a few BL slashs there. |
| | #8 |
| RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
| I had a 14 tooth pinion and 87 tooth spur with my 5700 motor and it would overheat. I now have a Novak 4.5 system in it with a 12t pinion and 90t spur, and the temps stay really low (no hotter than 130* with an outside temp of 70*+). With that motor I'd suggest getting a 90 tooth spur gear and a few pinions, like a 12/13/14/15/etc to fine tune it. A temp-gun is a good idea and reasonably cheap. Otherwise I've heard that if you can touch and hold your finger on the motor for 3 seconds or longer without burning it, you should be OK (but that's not as accurate, obviously). |
| | #9 | |
| RCC Addict ![]() Join Date: May 2006 Location: Roseville
| Thread Tools | |
| Display Modes | |
