| | #1 |
| I wanna be Dave ![]() Join Date: Jan 2005 Location: Hueytown, Alabama
| Ok guys. I did some trading with one of the guys on here and got a Blade CX. What would be some good upgrades to get for it? I know its the "starter" heli but from what I have read, there good to start on. I will definitely be getting a pro or moving up to another heli if I can get the hang of this one. Also, I use to fly planes a few years back but have never flown a heli. I have a few times on the sim and did ok with them. Any tips to help me get started? I dont have the heli yet but should be here within the next day or so. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Apr 2008 Location: columbus
| i had a cx and loved it super easy to fly and very controllable. i was able to put up the throtle and let it hover without touching the sticks. just fly it and you will find out you will need. i never upgraded anything on it. but make sure you stock up on blades the break very easy. if you so eventually go to a pro get a sim a nd practice a ton. because the two are very different. i got one and i crashed so many times i was going broke so i sold it and got into rock crawling. so just be willing to crash before you even get off the ground with the pro. |
| | #3 |
| Quarry Creeper Join Date: Jul 2005 Location: Dirty South
| I would switch to the common sense battry for it a go with it. For some reason the common sense battery gives quite a bit more power even though it is suppose to be the same. |
| | #4 |
| RCC Addict ![]() Join Date: Jun 2008 Location: Fresno
| i suggest getting the cf tail boom for it the slimmer profile make it a little easier to fly out doors and make it less vulnerable to gusts of wind. getting the xtreme sport canopy also helps. training gear is a must if your just learning to fly helis and stock up on blades, they're really inexpensive 2 full sets for under 8 dollars the main thing w/ the cx and beginers is setting it up properly you could probabbly go to your lhs and have them set it up for you for free or a nominal charge. keep an eye on what they're doing and ask lots of questions. Last edited by NeXt559; 12-16-2008 at 10:56 AM. |
| | #5 |
| Newbie Join Date: Oct 2008 Location: Hagerstown
| The first actuall part that I would upgrade would be the plastic rotor to the alluminum eflite part.Working at a hobby shop and selling a bunch of these that was the second part to fail next to the blades other than that its an excellent heli and you will have tons of fun with it |
| | #6 |
| Not to try and pick a fight but you will have very little chance to fly it out side. It must be a completely still day outside to fly. It is just not powerful enough to handle any wind to speak of. As far as a diffrent tail boom goes I noice very little change in how it flys with the smaller boom vs. the stock style, the only reason I changed mine is the stock one cracked. I personally had never flown a heli when I got my CX2 and I litterally opened mine and was flying decently. With in a couple of days of playing I could land on TV trays very consistantly. The CX is a pretty easy heli to fly.. I love mine. |
| | #7 |
| hmmm... i fly mine outside once in a while. im not saying im flying it in gale force winds but it can handle a slight breeze i moved the push rods a little further down the servo arm for a little extra throw in the servos to help fly it outside. |
| | #8 |
| I have mine moved up as well but if there is much of anything at ground level I can hang it up. Maybe I need to move them alittle more. |
| | #9 | |
| I wanna be Dave ![]() Join Date: Apr 2004 Location: SoCal
Mine has bee to the bottom of the swimming pool twice now and still works fine. batteries and all. | |
| | #10 |
| Thanks for all the replies guys. I will let you know about the first crash when it happens. |
| | #11 |
| Ok, got the heli, installed some new blades, one of the top shafts and a few little things. I have it flying ok but I am getting a bad glitch. The wierd part is that its only doing it on one servo. I tried using another servo I had gotten in the spare parts but its doing the same thing. So does it sound like the Gyro/receiver/speedcontrol part or the radio maybe? |
| | #12 |
| Well? Guess I will have to buy one and try it. |
| | #13 |
| take it to your lhs they should be able to diagnose the problem. if its a manufacturer defect they'll more than likely be able to replace the part w/ 0 charge |
| | #14 | |
| Who's your Daddy-0! ![]() Join Date: Mar 2008 Location: Augusta
| | #15 |
| Kenny, I actually brought it with me to ATL to get you or Jason to look at it. When I saw how tired you two were I didnt even think about it. Yeah, I have flown it outside a few times. Like I said before, I have flown planes so I am not new to flying. I know helis are a different thing but I still have fairly quick hands. Even with it glitching on me a little, I have been flying it low (within 5 to 10 feet) just in case it goes crazy. The glitch only seems to happen when I give input to go hard forward or back. I noticed something else with it at work today. I had the battery charged and everything trimmed out about an hour ago. It was hovering almost perfect. I threw the battery back on charge because I got a call. When I got back, it was charged. I took it up and the tail is spinning around on it hard now. |
| | #16 | |
| | #17 |
| This is an older one with the crystals. You were too tired....you probably would have crashed it. |
| | #18 | |
| | #19 |
| RCC Addict ![]() Join Date: Feb 2006 Location: ccxc
| get lots of spare blades and lots of skids! |
| | #20 |
| Thread Tools | |
| Display Modes | |
