| | #1 |
| Quarry Creeper Join Date: Jul 2005 Location: New Jersey.The land of NO!
| So we have a nice coating of ice on everything here in Jersey so I thought it would be fun to try out the slash.Well with my narrowed dirt hawgs I was gettin nowhere fast,anything more than 1/4 throttle sent the truck spinning,only fun for a few minutes.In my quest for traction I screwed a bunch of sheetmetal screws into the tires,this worked awesome for about 20 minutes and then all the screws starting flying out,I could hear them bouncing off the body!So then I built a set of snow chains,this took a few hours and they turned out awesome but they still didn't provide me with enough traction.So I had a thought,why doesn't someone produce a studded snow tire.I imagine an aggresive tread with metal studs molded into the rubber somehow.I know I would try a set!I have several frozen ponds on my property and would love to do some ice racing! |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Jun 2006 Location: Nor Cal
| Try these:http://www3.towerhobbies.com/cgi-bin...I=L5DT9202&P=K drill the holes in the spikes out and insert sheetmetal screws. That's what I'm going to do to a set |
| | #3 |
| Rock Crawler Join Date: Jun 2007 Location: Flat Rock Park
| Take the tires of get some 4-40 screws, washers and locknuts with locktie |
| | #4 |
| RCC Addict ![]() Join Date: Jun 2008 Location: Fresno
| i actually saw a snow/ ice conversion kit somwhere on line the other day had studded tires in the rear and ski's up front, sorry i cant seem to find the link though |
| | #5 |
| Rock Crawler Join Date: May 2007 Location: Franklin ME
| Put the screws in form the inside out. |
| | #6 |
| Rock Stacker Join Date: Jun 2007 Location: Norway
| Hello Made some for my Savage 4.6 some years ago. 3x13mm sheet metal screws, drilled 2,5mm hole in tyre from inside. Screwed in the screws, added rapid glue on inside - tightened screws. When dry I slightly bent the screws on the outside so that the hole in the tyre is visible and added another drop of rapid glue in the hols from outside. No problem with loosing studs even with the wheelspeed of the savage. Just made me some studded Geolanders (in same manner as above) for wintercrawling - a rock course is found on every streetcorner/parkinglot. Works amasingly good. |
| | #7 |
| Pebble Pounder ![]() Join Date: Mar 2007 Location: Kalispell Mt
| | #8 |
| You guys gave me some great ideas,I guess I will try to make another set using the bolt-thru method. |
| | #9 |
| Rock Stacker Join Date: Dec 2008 Location: Side of a MOUNTAIN
| ding ding ding... we have a winner! That's how we made ice racing tires back in the good ol days. Buy a VW Rabbit for $200, spend a couple evenings putting screws through from the inside, then glue on some rubber sheet with a coat with silicone, then a tube. Great fun on frozen lakes. The trick is to only have a little of the screw showing through- if they are too long, they rip out or push down inside. |
| Thread Tools | |
| Display Modes | |
