| | #1 |
| Rock Crawler Join Date: Jun 2008 Location: adrian,Michigan
| so I want to go brushless with my slash and I need some feedback on a couple different setups.I currently run a venom 4200 7 cell pack but am thinking of picking up either a 2s or 3s lipo. Still running stock gearing and wondering what gearing changes are reccomended for keeping temps safe. I don't race it just more of a basher round the track and yard. any input appreciated. thanks in advance. thinking of going with cc sidewinder 5700kv combo or 4600kv combo also considering the novak havk 8.5t sensored combo. all 3 around same price or maybe even with this combo http://cgi.ebay.com/Ezrun-RC-Racing-...1%7C240%3A1318 Last edited by discgolferlee; 12-23-2008 at 10:37 PM. |
| Sponsored Links | |
| | #2 |
| I wanna be Dave ![]() Join Date: Oct 2005 Location: Columbia TN
| I have a 4600 with a 3 cell geared to the moon and its useless over half throttle, a 4600 on 2 cells would be more than plenty. |
| | #3 |
| '08 2.2 National Champ ![]() Join Date: Nov 2006 Location: UTRCRC
| I've been running a Castle 4600 combo with a big 2s lipo for a while now and I woudn't want any more. |
| | #4 |
| I haven't changed gearing since I got it. I know it come swith the high speed pinion. I think stock is 18/86 and the extra pinion included is hmmmm no idea. never even took it out of package yet. any gearing reccomendations for the 4600 or the 5700. I think my LHS only has the 5700 in stock right now. |
| | #5 |
| Rock Crawler ![]() Join Date: Dec 2005 Location: Grand Forks
| I've got a Novak GTB with Velociti 5.5 (7400KV according to Novak's charts) in mine. I'm running some cheap Epic 3000 NiHms. I've got it geared way low at 13/86. It's top speed calculates out to about 36 mph with a run time in the range of ten + minutes. I don't know what my actual temps are but the motor and ESC barely get warm. The battery on the other hand has gotten pretty hot. I keep it geared down because of battery quality but the speed is still respectable. If I throw any more volts or taller gears at it will start getting into the crazy range. I already want to do some work to the diff to keep it from unloading in the corners. I roll it all the time on the street if I'm not careful about the whole throttle control and corner thing. 7 cells with the current gearing is about all want to go and still keep it what I consider controllable. |
| | #6 |
| Rock Stacker Join Date: Nov 2008 Location: Loveland, CO
| I put a vxl system in my Slash. 7 cell 5000 nimh packs. Stock gearing. Pretty incredible power and great run times for me. Not too short nor too long. I have since gone back to the stock set up xl-5/titan for snow bashin. You get a ton better handling if you add some 50k (or your choice)diff fluid. |
| | #7 |
| I wanna be Dave ![]() Join Date: Dec 2005 Location: Hawthorne, Florida
| Go with the 4600. plenty fast on 7-8 volts, silly fast on 3S. The 5700's get a bit warm in a Slash. |
| | #8 |
| RCC Addict ![]() Join Date: Jun 2008 Location: Fresno
| im also in the market for a new motor for my slash ive tried the 9,000kv and it was just way too fast. id get cogging at even the slightest hint of throttle (*mainly because i refuse to convert to lipo) when i finally get to speed the flightest bump in the road would get the thing airborn. and when i do use a borrowed lipo, a quick squeeze of throttle and the thing wheelies and flips over, even at speed i was thinking about going w/ the 5700kv, but like many have said the motor tends to get hot. would installing a heatsink onto the motor remedy the problem? if not a regular heat sink, how about one w/ a fan on it? since im using it mainly for bashing is the fan breaking off on a hard fall going to be a concern ? *btw should this be in the non crawler rc section? |
| | #9 | |
Great brushed: ![]() http://www3.towerhobbies.com/cgi-bin...&I=LXJAJ4&P=ML As far as brushless, I like the Velineon. | |
| | #10 |
| Pebble Pounder Join Date: Mar 2007 Location: kalispell
| 4600kv with Sidewinder on 7cell 4500mah is damn fast thats all you need |
| Thread Tools | |
| Display Modes | |
