Go Back   RCCrawler.com Bulletin Board > Miscellaneous > Non Crawler RC's
Thread: slash problems...please help
Old 12-27-2008, 05:17 PM   #1
Default slash problems...please help
Ok heres the deal...On a fully charged venom 7cell 3000mah battery it runs like normal when your holding it off the ground, but when you set it on the ground to run it it will hardly move...
thanx in advance
parker88 is offline   Reply With Quote
Old 12-27-2008, 05:27 PM   #2
I'm Dracula, Bitch.
JeremyH's Avatar
Make sure the slipper is tight on the tranny. I tighten mine all the way, then back off 1/4 of a turn.
JeremyH is online now   Reply With Quote
Old 12-27-2008, 05:43 PM   #3
I just set it too 1/4 turn counterclockwise from tight and it still does the same thing...
Old 12-27-2008, 05:58 PM   #4
mine is actually doing the same thing... only it started after i put in a brushless setup. i'm lost
4RunnerKid is offline   Reply With Quote
Old 12-27-2008, 06:26 PM   #5
I'm Dracula, Bitch.
JeremyH's Avatar
Hummm....do you hear any noise when you put it on the ground that is different than when you hold it off the ground? What are the specs? Got any pictures of your setup (body off)??
Old 12-27-2008, 06:34 PM   #6
re-program the esc,maybe you held the power button too long.
also check the 70/30 50/50 switch on the radio. 50/50 is where i run mine.
yz120 is offline   Reply With Quote
Old 12-27-2008, 06:44 PM   #7
I think I may have just found the problem...Whoever soldered the motor wire dosent know what the hell there doing...Whoops that was me...
Old 12-27-2008, 07:24 PM   #8
I'm a stupid C U N T!
slobin3d's Avatar
make sure you have all you're motor wires plugged in, and if its a castle system make sure all you're settings are correct
slobin3d is offline   Reply With Quote
Old 12-27-2008, 07:43 PM   #9
well I resoldered the motor wires and reprogrammed the esc and still the same thing
Old 12-27-2008, 09:08 PM   #10
I'm Dracula, Bitch.
JeremyH's Avatar
Yeah, I wouldn't think that a bad motor wire connection would show symptoms when it was on the ground but not in the air. Those symptoms would be present all of the time.
I still think that something is wrong with your gears. I would pull apart the trans and make sure that nothing is loose.
Old 12-27-2008, 10:09 PM   #11
allright Jeremy Ill check it out
Old 12-28-2008, 09:38 AM   #12
Wonder if your pinion gear is just loose enough to spin on the shaft under load. Lightly stripped spur, bad mesh. Check your ring gear, idler gear, doubt its that, but never hurts to check.
thunderwagn is offline   Reply With Quote
Old 12-28-2008, 02:31 PM   #13
that's all good
Old 12-28-2008, 04:04 PM   #14
Does this happen with all batteries or just this one? I have a pack that has a dead cell in it. The pack will charge and will work the same in the Slash off the ground. If I put it on the ground, the amps increase and the dead cell rears its ugly head and the volts drop to the point where it just creeps along. Pick it up, after a sec, all fine again. The battery works fine in a crawler as the amp draw isn't high enough to notice. Give that a check.
Trikster is offline   Reply With Quote
Old 12-28-2008, 04:10 PM   #15
Trikster that sounds like that could be a possibility...ill check into it and post up once i figure something out
Old 12-28-2008, 05:16 PM   #16
allright thanx to trikster my slash is back to normal...I switched in a 6 cell 3000mah nimh and it runs faster than it did with the 7 cell...shitty cells i guess
Old 12-28-2008, 05:57 PM   #17
Good to hear you got it fingered!
Old 12-28-2008, 06:36 PM   #18
Parker, you mentioned that it was a Venom pack...their packs may be low end, but if the pack is relatively new, send them an email, they might replace it for you.
Old 12-28-2008, 06:54 PM   #19
hmmm... i'm going to have to grab another battery and try mine. mine actually dies even with the slash off the ground... still could be battery though.
Old 12-28-2008, 07:27 PM   #20
its worth a try if you have a spare battery layin around...thanx
