Go Back   RCCrawler.com Bulletin Board > Miscellaneous > Non Crawler RC's
Thread: Stuffing 8 Cells in a Slash
Old 12-28-2008, 12:41 AM   #1
Default Stuffing 8 Cells in a Slash
I got a box from UPS yesterday that contained my aluminum shock caps and my new Integy 8 cell 9.6 volt 3600mah battery. I quickly realized that it wouldn't fit in a stock Slash's battery compartemnt so out came Mr. Dremel. I removed the cross bracing at the front of the battery compartment and shaved the thin piece of plastic at the back.
Now the 8 cell fits and the other 6 & 7 cell batteries that I have will fit with the stock foam padding installed.
Here is a short video of my Slash with the new battery. The motor and ESC are a Mamba Max 4600 Kv system.
http://www.youtube.com/watch?v=FNMSfRpIML8
nascarkeith is offline   Reply With Quote
Old 12-28-2008, 01:45 AM   #2
cool
josh hayes is offline   Reply With Quote
Old 12-28-2008, 09:12 AM   #3
Nice. Pretty quick Slash you got there.
thunderwagn is offline   Reply With Quote
Old 12-29-2008, 09:43 PM   #4
I'm a stupid C U N T!
slobin3d's Avatar
nice that you made it fit, but I have to ask why you went with a 8 cell flat pack instead of doing a 8 cell hump so the extra 2 cells would stick up through the battery strap?
BTW my slash will be here friday and I'm swapping out my MM7700 and 8cell from my rustler into it
slobin3d is offline   Reply With Quote
Old 12-30-2008, 05:51 PM   #5
That is how I did it in mine, the 2 cells fit in the strap nicely.
william g is offline   Reply With Quote
Old 12-30-2008, 08:14 PM   #6
I was ordering some parts from tower and added the battery on at the last minute. When I ordered I didn't see an 8 cell hump pack and I thought it would fit if I removed the foam. When I got it and it didn'f fit I just decided to make it work. Now, my 6 cell and 7 cell hump packs fit with the foam installed turned around running long ways with the chassis. I guess an added benefit that I just thought of with my set up is that it keeps the weight lower.
Old 01-03-2009, 01:29 AM   #7
be carefull....
the slash is too big for the 7700 kv motor. watch the temp cause i thermaled my mamba max when i was running that motor and i had i geared as low as you can go. I recommend running a different motor in the slash. the 7700 is fun in a drifer though....
mtnyote is offline   Reply With Quote
Old 01-04-2009, 09:01 PM   #8
good mod. now if your esc can handle it, you can custom build a 10 cell pack for it.
jeepcreep is offline   Reply With Quote
Old 01-16-2009, 04:32 PM   #9
my 8 cell hump pack fits nicely in mine.
BEAST02 is offline   Reply With Quote
Old 01-16-2009, 04:58 PM   #10
1 man, 2 sons
Unimoger's Avatar
Originally Posted by mtnyote View Post
be carefull....
not too worry, slobin and I have the same rig, they only run for 2-3 mins and then we blow something up anyway. Something about 70 mph and plastic parts, just don't work too well.
Unimoger is offline   Reply With Quote
Old 01-16-2009, 07:45 PM   #11
How do you keep it to the ground @ 70
Mine hits lift off around 40
