Go Back   RCCrawler.com Bulletin Board > Miscellaneous > Non Crawler RC's
Thread: so i just gota high roller...
Old 01-05-2009, 11:28 PM   #1
Default so i just gota high roller...
The plan is a basher with additude.
Pulling the 4600kv out of the creeper and putting it in the high roller. dual shocks front and rear. and 12 cells just cause I can.
werty is offline   Reply With Quote
Old 01-05-2009, 11:31 PM   #2
ΜΟΛΩΝ ΛΑΒΕ
chip cross's Avatar
Originally Posted by werty View Post
4600Kv and 12 cells just cause I can.
Good luck with that, better watch your temps.
chip cross is offline   Reply With Quote
Old 01-06-2009, 01:20 AM   #3
why not just run 3s lipo?
dieselfuel is offline   Reply With Quote
Old 01-06-2009, 08:36 AM   #4
On the lookout for Rocks
constantmotion's Avatar
unless your talking about a 12 Cell LIPO............
constantmotion is offline   Reply With Quote
Old 01-06-2009, 09:19 AM   #5
i have a stampede with a 5700 mamaba max and run 4000mh 6cell and WOW talk about wheels on demand. lol you will have fun with your high roller and all i can say is if it doesnt already have a wheely bar get one or make one for it. Click the image to open in full size.
bugz2002 is offline   Reply With Quote
Old 01-06-2009, 11:05 AM   #6
I saw this on ebay makes me wonder how much torque i can get out of it.
http://cgi.ebay.com/TWO-SPEED-Transm...QQcmdZViewItem
Old 01-06-2009, 11:09 AM   #7
binaryterror's Avatar
Well since its a highroller its gear will destruct quickly...then the slight breeze or a tiny slow speed hit will break it.
Losi's name is tarnished because its on this thing. This should have been put under the SportWerx name...
binaryterror is offline   Reply With Quote
Old 01-09-2009, 07:39 PM   #8
Death before Dishonour
canadianbacon's Avatar
Why, mine hasn't broken yet, been bashing since I got it (Nov.15th).
canadianbacon is offline   Reply With Quote
Old 01-19-2009, 10:54 PM   #9
here is the set up.
bashing videos.
http://www.youtube.com/watch?v=shD9VpG7A_w
http://www.youtube.com/watch?v=Owsewziq3RU
ok for binaryterror i finally broke it. on of the shock ends busted after a triple front flip after 15 feet of air.
Old 01-19-2009, 11:14 PM   #10
701 Technique's Avatar
Sweet vids, I dig the tunes.
Brushless RCs can definitely hurt babies man:-( I had a close call with a rusty doin about 45mph (baby came outta nowhere for real)
Keep it safe
701 Technique is online now   Reply With Quote
Old 01-19-2009, 11:33 PM   #11
Its funny i get him all these new toy but all he wants to do is run with the big boys. He is the flip over king i flip it then he rights it. His motor skills are getting good he can steer or run the throttle, but not both yet. I give it 6 months and he'll be on his way to be the next top dog on the courses.
The 4800kv isnt good enough I have a 6900kv on the way. 9.9v a123s and a bigger pinion. 68000 rpm. more power and bigger jumps.
Old 01-20-2009, 01:44 PM   #12
lol I don't think the tranny will survive that motor, but one good thing is replacement gears are cheap, like $4.99 I believe it says in the book.
Old 01-23-2009, 07:59 PM   #13
well the front pivot block didnt survive the tree. 45ish with a 6900kv and 9.6v Till I hit that tree.
Old 01-25-2009, 08:13 PM   #14
Or maybe its just the driving skill thats the problem......... :-P
tom tom is offline   Reply With Quote
Old 01-26-2009, 09:19 PM   #15
ok todays run killed the tranny time for some steel gears. or a pede tranny morfted into the high roller. 6900kv 9.9v an way to much hp!
Old 01-26-2009, 09:40 PM   #16
im running the 6900kv on 2 cell in my slash and its just stupid fast
mental is offline   Reply With Quote
Old 01-27-2009, 11:26 AM   #17
ya any time you can pull a wheely 3/4 into the throttle and still can't touch full throttle, fast is a under statement.
Old 01-28-2009, 12:26 AM   #18
How do you like your high roller?
starvenamrvin is offline   Reply With Quote
Old 01-28-2009, 09:29 PM   #19
I like it, with the brushed motor it was a blast. Just tooling around the backyard. jumps good, It is easy to straiten out in the air.
few things: Get rid of the stock steering servo I upgraded to a MSX high torque LOSB0819
steering servo.
The big thing is the gears went out two fast. The first set was ok till I put the 6900kv in it. The second set lasted 2 battery packs I think the a123 9.9v and the motor being so hot kill's stock gears.
But there is hope.
I just heard losi is coming out with some steel gears for a hop up. I will be testing them before I give up hope on the high roller as a great basher.
Big thanks goes out to Rich Trujillo. He is the one that saved this roller form being a ebay item.
It has the platform to be a crazy basher if the steel gears hold up.
Hope this helps you starvinmarvin!
Old 01-29-2009, 12:13 AM   #20
Sounds like the Mini LST all over again. I really like the look of the high roller but, without steel gears its a waste to go bl. Hopefully losi will come out with some steel gears for it, I mean its all about lipo and brusless now.
yarddog35 is offline   Reply With Quote
