10-06-2009, 06:36 PM | #1 |
Pebble Pounder Join Date: Nov 2008 Location: Reno NV
| Amc Pacer Street and Strip Custom OR Rat rod Build
Dont know what to do with it yet, need to make a frame and figure out a rear axle setup, may go with a MRC rear axle and custom front setup. Heres 2 photos so far, Need to fix the rear wheel wells.
10-06-2009, 07:41 PM | #2 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
put some meaty size foams on the rear and some skinny's on the front. budget drag car
10-06-2009, 08:42 PM | #3 |
Yes! chop the top some how! |
10-06-2009, 08:46 PM | #4 |
Ratt Rod that bitch! |
10-06-2009, 11:03 PM | #5 |
Quarry Creeper Join Date: Nov 2008 Location: Lightin' The Desert In
Make It A Street/Strip Car! An Make It Drift! A Slammed Pacer that Drifts?! Helllllllyaahhhhhhhhhh |
10-07-2009, 06:21 AM | #6 |
Rock Stacker Join Date: Dec 2004 Location: Logan, QLD , Australia
Its the mirth mobile lol
10-07-2009, 09:01 AM | #7 |
Pebble Pounder Join Date: Jul 2008 Location: Toronto
mmmm, pacer with roof rack, friend of mine had that exact car in 85
10-07-2009, 09:54 AM | #8 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
Sleeper/Pro Beater, make it look like just a beat up street car that ust don't quite look "right" (like bigger than normal tires and exhaust, more of a street machine style stance, ect)
10-07-2009, 10:30 AM | #9 |
Thanks Guy's for all the good comments, I am hoping to try this out as a sleeper ratty looking Pacer that will go fast, I have a line on a brushless system, mm 5700kv on 3 cell lipo ? My question is should i make with a rear axle, like a losi mini crawler axle? as for the stance it will be as low as possible! Anyone know who is a good painter, I would like to have a faded beater paint job on it? |
10-07-2009, 11:44 AM | #10 |
Rock Crawler Join Date: Jun 2007 Location: Great Britain
Chuck a TT01 chassis under it with a set of oil shocks and an alloy main shaft. They take a hell of a beating and you can get loads of upgrades if you do break anything. Plus you could drift it when you get bored of driving straight lines. |
10-07-2009, 01:14 PM | #11 |
Newbie Join Date: Jan 2008 Location: Margaritaville
What's the wheelbase and width at the wheels? I vote TT-01 if the dimensions are right. If it has odd dimensions, go with a full tube dragster. The rear wheel openings are a little out of proportion and look like a drag car. As far as the paint job, go with the mirth mobile |
10-07-2009, 03:18 PM | #12 |
The wheel base is right at 10.5 inches, width is 8 inches fender to fender, This is for front and rear. With a little modification it could fit my tc4 frame. But I would like to have it solid axle in the rear and NO AWD. I would really like to find a Losi mini rock crawler axle. |
10-07-2009, 06:07 PM | #13 |
What about a standard or narrowed TLT? Are MRC's strong enough for launches and such? . . . 10.5" is the short CC-01 isn't it? Would it work on one of those? You could make it 2wd by removing the front dogbones and drive gear, and the CC-01 rear axles are supposed to be fairly robust. Whatever you do with it, you can't go wrong with the Pacer body. |
10-07-2009, 06:24 PM | #14 |
So I thought to use some leftovers from a hpi car and make it work for the pacer, so cut down the middle and took the front drive gears out and now need to mount the shock towers, What i would really like to do SOME DAY, is make this a old gasser with the front end sticking way in the air. Maybe some day! If I could find a narrowed tlt I would rather run that, The body will fit on cco1 as I have one all ready, A cco1 rear axle would work also. Just cant find what I need. |
10-08-2009, 06:42 AM | #15 |
Quarry Creeper Join Date: Sep 2005 Location: Lethbridge
You could run a MRC diff. it be narrow but that just gives you room for more rubber. |
10-08-2009, 10:09 AM | #16 |
Gasser... What about one of those front axles from a semi? Shaving all the trim from the car and painting it flat black or gray would definitely give it a gasser look. |
10-08-2009, 10:56 PM | #17 |
a guy on groovydrift.com set up a tc4 for only rear wheel drive; he took the drive shaft out of the front so its only rwd. theres a pic of him on the website smoking a set of foams doing a burn out. you do a on road car chassis; *tc4, tto1,etc* but dont put any in tth front diff. only use the suspension parts. i did a similar kinda config on my rustler *off topic-sorry* I used my hpi mtw suspensions parts an a made my suspension a wide travel setup. *hpi mt2 is 4WD* But like is said, use a on road car chassis; but dont put a front drive shaft in it so its only RWD |
10-13-2009, 07:43 PM | #18 |
More done, I am going with the mrc rear axle, found some tires for the back, They look funny but very wide Hope to use them, I may cut and narrow the rims and tires. :? I did get the front shock mount in and will be working on the steering next, and soon the axle will show up. Here's the updated photos |
10-15-2009, 06:46 PM | #19 |
The wheels and tires look perfect in that side pic. |
10-15-2009, 07:43 PM | #20 |
this is gonna be good.
