02-15-2010, 03:53 PM | #1 |
Pebble Pounder Join Date: Nov 2008 Location: Reno NV
| Crosley Wagon Build
I had an idea of building this body from scratch for a long time now. My problem is sizing the photo for a scale match for what i need. I have photo shop but no idea how to use it. As for the build, its ether going stock or hood ride/rat rod look using a Tamiya chassis and building the body from styrene. Here's the photo and helping hands are always welcome. |
02-15-2010, 04:44 PM | #2 |
Quarry Creeper Join Date: Nov 2005 Location: LBC
If you can find out the original wheelbase, I can help you scale the pics. I'm an automotive designer by trade and have to deal with this stuff all the time. send me a PM if you need help figuring it out. ...and if you like my lil gasser build maybe you'll wanna go that route too! |
02-15-2010, 05:07 PM | #3 |
Pebble Pounder Join Date: Dec 2008 Location: Sykesville
This might help. http://crosleyautoclub.com/ I also sent my father an email, he has a 49 wagon and most likely knows or can find out any spec you need. Edit: Dad replied The wagon should be: Wheelbase is 80" Center of Tread to Center of tread is 40" Body is 48" Wide About 12' long bumper to bumper Some other fun full size projects: ] ] Last edited by Typhoon; 02-15-2010 at 05:25 PM. |
02-15-2010, 05:33 PM | #4 |
Thanks Guys, I love the rat rod Crosley, That's Bad A$$, Is it yours? On a building note, I want to use a m03 frame, there easy to work on and a good plat form. Would i just blow up the photo to fit over a frame and start building or is there a better Way. Thanks Off to the lhs for styrene. |
02-27-2010, 03:44 PM | #5 | |
Could you ask your dad for a photo of the back door and a front end photo both straight on, i cant seam to find any! thanks Quote:
02-27-2010, 08:18 PM | #6 |
| Update
Will here's an update. I bought a m02 from another member, and drew up the body on poster board to start making the body out of styrene. The front end will be the hardest. I am copying the drawing for the passenger side. Hope to start building the body tomorrow. |
02-27-2010, 08:34 PM | #7 |
Or I could do this. |
03-01-2010, 01:54 PM | #8 |
03-01-2010, 02:14 PM | #9 |
thanks, that helps. |
03-04-2010, 10:17 PM | #10 |
| So it starts
Well made some ruff cuts for both sides, some lines a little off, but will be able to remake them with putty. I have both sides like this. Now just got to glue them up. AS for the roof I am going to use flat styrene and then add foam and make the shape i need. I may do this for the hood and grill area. Any other styrene builders out there. What do you use to cut very straight lines, mine look like a five year old did it. Enjoy, more to come soon. mrgreen:
03-04-2010, 10:19 PM | #11 |
Quarry Creeper Join Date: Dec 2008 Location: Santa Mira
Go for it!
