01-25-2006, 11:13 AM | #21 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
HOLY ****! Just crunched numbers on this. The Novak 5800 setup will handle up to 7 cells at 1.2V per cell. The motor spins at 5800RPM per volt. After crunching the numbers here's what I get. 1st gear ratio: 4:1 2nd gear ratio: 2.6:1 Tire diameter: 3.4" Tire circumference: 10.7" Motor RPM @ 8.4V: 48720 So, after doing the math: Max speed if in 1st gear: 64MPH Top speed: 98.7MPH Of course this is all in theory. Wind resistance will make the top speed a good bit lower, but still...not bad for a pile of junk that was laying around. Last edited by JasonInAugusta; 01-25-2006 at 11:15 AM. |
01-25-2006, 11:45 AM | #22 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
Sounds interesting. Can't wait to see how it works out especially with the 2 speed. With that kind of power you might want to go with foam tires. I doubt the rubber will be able to hook up. |
01-25-2006, 12:13 PM | #23 |
Rock Stacker Join Date: Jan 2006 Location: under a rock
you better get moving man and post more pics
01-25-2006, 12:57 PM | #24 | |
Pebble Pounder Join Date: Oct 2005 Location: I need MORE GIGGLE JUICE
01-25-2006, 01:18 PM | #25 |
I won't be running against nitro drag cars, just the touring cars that the locals think are fast. ;) Rear wheels are Torkerz with Pro-Line Striker IIs The Torkerz are a pin drive, not a hex. Fronts are narrow 1.9" HPIs (I think they're discontinued) with these tires. |
01-25-2006, 03:58 PM | #26 | |
Quarry Creeper Join Date: Jan 2005 Location: New Orleans
Wow this is awsome! Looks like I'll be starting another project soon! Quote:
01-25-2006, 04:52 PM | #27 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
Sweet. I made a pan car/dragster but lost interest as soon as I finished it. It has a custom G10 chassis, no suspension, solid axle rear, direct drive, 32p gears, buggy rear tires and sedan front tires Heres my axle, maybe it will give you some ideas It spins on 1/4x5/8 bearings and uses 1/4-20 wheel nuts. That is a T Maxx spur bolted directly to the shaft |
01-25-2006, 05:57 PM | #28 | ||
Quarry Creeper Join Date: Feb 2005 Location: Yuma
im not positive but i think the lhs has a set or two of those front rims in the bargin bin, if you want ill take a look and see if you want me to. | ||
01-25-2006, 06:43 PM | #29 |
Rock Stacker Join Date: Jun 2004 Location: huntington beach cali.
If you ever make any more of these. LMK, i have a Novak SS5800 just sitting here waiting for something.
01-25-2006, 06:58 PM | #30 |
Rock Crawler Join Date: Oct 2005 Location: Clarkston, MI
I thought you were using Duratrax Street Trac tires, those could be an inexpensive alternative.
01-25-2006, 07:09 PM | #31 |
Rock Crawler Join Date: May 2005 Location: omaha
JIA, be careful with that 2 speed, the clutch finger for 2nd gear will rip the pin right out. I did it in my HPI three times. Thier 2 speed can only handle down to about a 12 turn motor That is the two speed for the electric TC? |
01-25-2006, 07:40 PM | #32 |
Yup, the electric version.
01-25-2006, 07:51 PM | #33 |
Good luck, if those rear tires hook up well it will eat the 2 speed. Tires that big should have a heck of a lot more traction than my little TC tires. If you need extra parts for the 2 speed, I got them.
01-25-2006, 08:18 PM | #34 |
grr. I kinda thought I'd be pushing the limits of the 48P gears. We'll see. |
01-26-2006, 12:54 AM | #35 | |
01-26-2006, 07:44 AM | #36 |
Rock Stacker Join Date: Jan 2004
nice job, that hpi chassis should be pretty stable, i like how the wheels are tucked in the fenders too. i did mine on a pan car chassis motor is a 15 turn just to get it to move. i built it for the fast and furious thing i've got going on (have the supra, eclipse, skyline, and rx-7) a better shot, body needs to be lowered a bit tho this is the real drag vehicle (besides my new era rail) chassis is 10l4, motor is 6 turn cobalt, novak 828, and anything from 8 cells up... rc car action did almost the same car, but used a 12 turn and 8 cells, their radar'ed top speed was 64 mph.. i think i should beat that.. although it's got to punch a big hole through the air w/ the truck body.. bdr Last edited by bigdogrod; 01-26-2006 at 07:50 AM. |
01-26-2006, 08:02 AM | #37 |
| Nice job on replicating the charger looks like the real deal straight from the movie. Mike |
01-26-2006, 09:07 AM | #38 |
Rock Stacker Join Date: Jul 2005 Location: hour south of nashville TN
Excellent idea. Excellent execution. The color though. Do you have anything in mind? Single color, or something more graphically intense? (cage?) Last edited by thebigJAT; 01-26-2006 at 09:16 AM. |
01-26-2006, 11:34 AM | #39 | |
Rock Crawler Join Date: Aug 2004 Location: Concord Ca
01-26-2006, 11:56 AM | #40 | |
will do! | |
