09-17-2011, 10:24 AM | #1 |
RCC Addict Join Date: Mar 2011 Location: easton
| hpi cup racer questions
just got a new hpi cup racer yesterday from the lhs for $200. (this is my first hpi) turns out the thing was already built but they didnt follow thru with everything. they used parta from both kind of shock layouts so now i have to fix it, no big deal but annoying! the front shocks are stand up right now, im going to re do it so they are lay down. it has a 510 body but i need a new one because theres no rear bumper! the tires are rubber but they have no tread. are they drift tires or not? heres a pic it has the battery holder for a stick pack. will i be able to run a 2 cell lipo with it or do i need to change it? i want to run mamba maxx brushless or sidewinder brushless but how fast/ difficult to control would this thing be with a 210 mm wheel base? |
09-17-2011, 10:39 AM | #2 |
just found the answer to the tire question. the tires are mx 60x26 which means there rubber non drift tires
09-17-2011, 05:30 PM | #3 |
You should be able to download or at least view the manual at HPI's site. There's a square battery tray for lipos, and good luck getting that foam bumper inside the 510 body |
09-17-2011, 10:52 PM | #4 |
Rock Crawler Join Date: May 2005 Location: Fort Wayne
Here is the manual ... http://www.hpiracing.com/manuals/pdf/100594.pdf Those are the stock tires that come with the kit. There is a specific part for lipo batteries unless you get the ones in the hardcase that look like a regular shotgun style pack. |
09-18-2011, 12:10 AM | #5 |
thanks i have the instruction manual that came with the car and redid the front shocks already. im going to try and get a new 510 body on tuesday and some electronocs. do you guys know if a 190mm body will fit? i think it might be to big but i want to make sure. if it doesnt ill get a 510 and cut the foam bumper to make it fit. what would be a good brushless system and pinion for these that will make it haul azz but not be stupid fast? im probably going to get a jr servo |
09-18-2011, 02:46 PM | #6 |
You'll need a Cup Racer body. Touring-car bodies are too long (WB is off by about an inch). You might find a Bolink or Mini Cooper body that will fit.
09-18-2011, 05:17 PM | #7 |
ok ill try and get another cup racer then. oh what led kit works with these?
09-18-2011, 10:02 PM | #8 |
Any LED kits designed for a touring car will work. Cup Racer or Mini bodies will work. Just make sure they say they are good for a 225mm wheelbase.
09-19-2011, 05:52 AM | #9 |
09-19-2011, 01:22 PM | #10 |
The 510 is designed for a 225 wheelbase. I have the car myself and chose that wheelbase due to the fact that there are more body options in that wheelbase.
09-19-2011, 01:58 PM | #11 |
oh what kind of electronics are you running in yours?
09-19-2011, 04:14 PM | #12 |
Currently I am running a basic setup of the HPI X30 motor with a Dynamite Tazer ESC so that my wife can enjoy driving it. Later on I plan on putting in a brushless setup though at this point I'm not sure which one.
09-19-2011, 04:50 PM | #13 |
Rock Crawler Join Date: Aug 2011 Location: Baton Rouge
I have a cup body and light set too if u want it? PM me. |
09-19-2011, 06:15 PM | #14 |
ok im probably going brushless on it. just not sure which system to get tho.
09-20-2011, 09:47 AM | #15 |
09-23-2011, 08:16 AM | #16 |
ok what upgrades would you reccomend for brushless
09-28-2011, 08:52 PM | #17 |
got the new cup racer body, and i ordered a yeah racing drifter led kit
