| | #1 |
| Newbie Join Date: May 2006 Location: BFE
| got some buddies that say once i get my crawler built they will be able to out pull me with their gas trucks. in the end im not sure but last time i checked low gears and torque (diesel trucks and tractors) always won not speed and hi revving??? what do you all think. also any tips to put things in mine that will help me win hehe |
| Sponsored Links | |
| | #2 |
| Quarry Creeper ![]() Join Date: Sep 2005 Location: Lufkin
| Well I can tell you that my crawler, with the pede tranny, 55t lathe motor, 12t spur and an 87t pinion will pull a surprising amount of weight. I was sitting in a wooden drawer with wheels that prolly weighed 10-15lbs and my crawler pulled me around just fine, I weigh 156lbs. So you might just out pull them if you can get the power to the ground. |
| | #3 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| Two of my friends got outpulled by a savage the other day. They had electric pullers. It was quite shameful to see. |
| | #4 |
| Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
| I pulled my brother and me on one of those scoot n' do or whatever they are called garden things. Together we weighed about 280 lbs. I am running pede trans, 87 spurr, 13 pinion. I should also say when I tried to pull myself with my maxx I barley moved at all. |
| | #5 |
| Quarry Creeper Join Date: Apr 2006 Location: the creek
| weight of the vehicles will have a big effect. add a 5 lbs weight somewhere... |
| | #6 |
| Rock Crawler Join Date: Jan 2006 Location: In the basement
| id say youd have more opportunity to win... electric motors can produce more constant torque, thats why trains use a deisel generator to power the electric motors to move the thing.... a lot of the reason the nitro vehicles can pull more is because they are much bigger and the ratio of weight between the sled and the R/C is closer... with that said i think you can beat any nitro vehicle with a decent electric motor |
| | #7 |
| Quarry Creeper ![]() Join Date: Dec 2005 Location: Mechanicsville, VA
| It's all about the weight of the rig. If you're running lathes and are geared all you need is more weight. A good example is when several years ago I hooked my '84 Buick 4dr, AKA- The Ark, to my buddies 4x4 Ranger and pulled him across the parking lot. My car was 2wd and had an open rear but weight the better part of 1,5k lbs+ more than his truck. My old 2.2 Clod with 55t's pulled a 15lb trailor w/ about 50-60lbs on it with no added wieght. I then added a 2liter bottle full of water to the bed and proceeded to pull my 1:6 Nylint across the CARPET. |
| | #8 |
| I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
| Pulling sled = broken parts This shows with out weight add to the truck and with weight add to the truck. |
| | #9 |
| Quarry Creeper Join Date: Nov 2005 Location: Valencia
| my clod, two 65t and 8tooth pinion, pulled me sitting on a rolling chair and im 180 |
| | #10 |
| Haters gonna Hate ![]() Join Date: Mar 2005 Location: In the Basement building Hiluxs and shit
| I have need scene a gas truck out pull a truck in a tug of war. Even gayass RCC did a emaxx/tmaxx shoot out and the emaxx dragged the tmaxx around like a rag doll. Its all about how you set your truck up, you want your wieght forward, tires with alot of traction and something with a v-thread so itll clean the dirt out, your also going to want as low as gear as possible in most cases AND alot of go juice, at least 7 cells, more like 8 if you can. I pull in the NCRTPA in the box stock class... This clod drags 60 lbs with out a problem on dirt on 7 cells with 2 integy 55s turns, 9 tooth in the rear and 10 tooth in the front to fight clod stall... ![]() Here is dragging around a TTR Ripper before the lathes and pinions ![]() Its all about your set up, if you set up right you should be ok, I wouldnt hesistate to out this up against any gas truck Mike |
| | #11 |
| Newbie Join Date: Jan 2006 Location: kansas city
| just look at hotrod trucks and tractors. in the dirt the nitro will eat up an electric. wheel speed is a +. on hard surface tho the electric might be better. |
| | #12 |
| Pebble Pounder Join Date: May 2006 Location: Scottsdale
| wow I had no idea these things could pull us around, I haven't completed my TLT yet but I can't wait to see if it pulls me. |
| | #13 | |
Mike | |
| | #14 |
| Rock Crawler Join Date: Feb 2006 Location: Clovis, NM
| In a pulling contest I'd beat on the electric everytime. Like stated above, instant torque. Mine pulls me on a skateboard, and I weigh 203lbs. |
| | #15 |
| So what have we learned folks. Fastest top speed = electric wins Pulling the most weight = electric wins Why nitro then? So the electric guys have someone to embarrass. |
| | #16 |
| Newbie Join Date: Feb 2006 Location: Longmont
| What about tires and rims? Pro-Line, Imex, etc. 2.2, clod size, 40s, maxx. I got my a$$ handed to me by a stock T-maxx with my stock clod wheels on my 13lb crawler. Later on with my moabs 1/2 throtle on my part was all it took to run around like the t-maxx was just sitting there dead. |
| | #17 |
| Prick ![]() Join Date: Aug 2005 Location: Bargersville, Indiana
| That's like comparing bubblicious to PVC pipe....... |
| Thread Tools | |
| Display Modes | |
