07-27-2012, 12:29 PM | #1 |
Newbie Join Date: Jul 2012 Location: Canada
| The Person with lots of questions because im new to all of this. Please help
Hello, im new to fourms and new to these RC's. im purchasing the yokomo 1:10 scale B324R as a starter; i went into deep search and i found that you can do a lot with these RC's so i want to make the RC counter steer and have all these LEDs. but first i need to find out these all are. some are self explanatory. the list concludes that these are not included Radio - 1 X (2ch) Transmitter Receiver - 1 X (2ch) Receiver Servo - 1 X Steering Servo (Standard Size) Battery - 7.2v Sub-C or 7.4V Li-Po Charger - 1 X Battery Charger TX Battery - 8 X 2AA battery Parts - Spare Parts Tools - Tools Instant Cement - Tires Glue Paint - Sorry!Out of stock!!! ESC - Brush/Brushless ESC Motor - Brush/Brushless Motor Hop Ups Parts - Hop Ups Parts for MR-4TC could some please explain to me what i need and how it all works? thanks. and oh yea, for the countersteer i found that the "Yokomo FCD 2.0" works great but i see so many different parts so im confused on what i need, the axle, or the gear, or both or does it come with it. this is the one im looking at Yokomo FCD Solid Axle Set Rear 2.0 (D-051) [D-051] - €24,96 : Race & Drift Japan thanks in advance, cheers! |
07-27-2012, 02:25 PM | #2 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
| Re: The Person with lots of questions because im new to all of this. Please help
Check out the drifting or touring forums. Maybe you should buy a used one first or one thats ready to run (RTR) perhaps?
07-27-2012, 09:57 PM | #3 | |
| Re: The Person with lots of questions because im new to all of this. Please help Quote:
2 Channel Radio Receiver Motor ESC Servo Charger Sub-C Type 7.2V Battery (6 Cell) Stick Pack & Side-by-Side Pack Compatible and could you explain what the receiver esc and servo does? thanks | |
07-27-2012, 10:01 PM | #4 |
and also what is brush and brushless ESC/Motor?
07-29-2012, 02:16 AM | #5 | |
MODERATOR Join Date: Oct 2010 Location: RC Land
I am sure I will miss a LOT of important facts for your answers and hopefully not be incorrect with anything I say.... But here is a "Reader's Digest" quick answers to some of your questions. If I am incorrect with anything I say below, I hope someone corrects me so you are not misinformed. An ESC is what electronically controls the speed and potentially the dynamic braking of your RC. Basically, it takes your electronic signal and controls the mechanicals. -----The TX is your transmitter (the controller that you hold in your hand) -----The RX is the receiver (catches your transmitted signal from the TX) The RX is where everything plugs in..... Kinda the brain of your rig so to speak. Catches the signal and separates things off to each item plugged in... --ESC, Servo/servos, dig servo, lights, winch etc... -----A Servo is what controls your steering, dig, some winches etc... Basically a servo is a small device consisting of * Mechanicals (the gears from motor to final output) * The motor (which provides power to the output arm through the mechanicals) * The feedback pot ( Which allows the servo to determine the location of the arm in relation to the TX) * The amplifier ( which basically connects everything together and makes things work) * And of course you can option which servo you use by the gears... Plastic, nylon, brass, steel, aluminum.... * and to confuse you more... You have the option of using an Analog, Digital, Coreless or Brushless servo Then if you want Brushless or Brushed motors....... ----Brushed basically has 2 rotating wire coils (armatures) spinning in the center of 2 permanent outer magnets ----Brushless basically has 3 fixed position outer coils with a permanent external magnet rotor Brushed motors are not picky about their environment and operate in extreme environments. They are low cost to construct, so in turn are low cost to purchase Easily rebuildable But.... Require regular maintenance Do not dissipate heat very well Not the best for high speeds Brushless motors are a bit picky about moisture and sand They are a bit more complicated which relates in the costs Fairly maintenance free Compact in size with comparison to power Heat dissipation at more efficient rate because windings are directly connected to outer case But..... More expensive Control for motor is more complex then brushed which can sometimes cause the ESC to be twice the price of the motor. . | |
07-29-2012, 11:24 AM | #6 | |
my chassis is still in the process of being brought over seas. now that i re look at the parts i have right now i have a few questions about them. http://i1055.photobucket.com/albums/...C/P1090534.jpg -at the top left, i have 2 servos, do i need 2? and what are the fan blades? -bottom left its a 27MHz AM RECEIVER is 27mhz good or bad? and it has 3 slots, battery, ST and TH, whats the ST and TH for/stand for? -then i have no clue what the battery slot thing is, it seems to have an on and off switch. -then on the right thats the ESC it says its a 1 time setup, like when everything is ready i just press that button above the sticker and it activates im assuming and will only have 1 shot at it. it also says "Tazer 12T FORWARD | REVERSE" on it. i also noticed when i look at countersteer which i plan to get next, theres "#T" on it as well. does it mean that i can only choose ones with the matching turns? i plan to get the yokomo FCD 2.0 CS if you could help me with that as well, id be appreciated. and lastly the motor, do i remove that black tubing or is it suppose to be like that? thanks! | |
07-29-2012, 11:26 AM | #7 | ||
okay, thanks, gave me some what of an understanding, now i have a few more about this. my chassis is still in the process of being brought over seas. now that i re look at the parts i have right now i have a few questions about them. http://i1055.photobucket.com/albums/...C/P1090534.jpg -at the top left, i have 2 servos, do i need 2? and what are the fan blades? -bottom left its a 27MHz AM RECEIVER is 27mhz good or bad? and it has 3 slots, battery, ST and TH, whats the ST and TH for/stand for? -then i have no clue what the battery slot thing is, it seems to have an on and off switch. -then on the right thats the ESC it says its a 1 time setup, like when everything is ready i just press that button above the sticker and it activates im assuming and will only have 1 shot at it. it also says "Tazer 12T FORWARD | REVERSE" on it. i also noticed when i look at countersteer which i plan to get next, theres "#T" on it as well. does it mean that i can only choose ones with the matching turns? i plan to get the yokomo FCD 2.0 CS if you could help me with that as well, id be appreciated. and lastly the motor, do i remove that black tubing or is it suppose to be like that? thanks! | ||
07-29-2012, 11:28 AM | #8 |
07-29-2012, 12:31 PM | #9 |
| Re: The Person with lots of questions because im new to all of this. Please help ...I gave you a link for a great drifting forum, I don't understand why you're not asking for help over there. I could see that if you were a long time crawler and were looking into drifting, you might post up some questions here...but being completely new and doing this makes no sense.
07-29-2012, 07:40 PM | #10 | |
07-29-2012, 07:59 PM | #11 | |
http://i1055.photobucket.com/albums/...C/P1090534.jpg at the top left, i have 2 servos, do i need 2? bottom left its a 27MHz AM RECEIVER is 27mhz good or bad? and it has 3 slots, battery, ST and TH, whats the ST and TH for/stand for? then i have no clue what the battery slot thing is, it seems to have an on and off switch. then on the right thats the ESC it says its a 1 time setup, like when everything is ready i just press that button above the sticker and it activates im assuming and will only have 1 shot at it. it also says "Tazer 12T FORWARD | REVERSE" on it. i also noticed when i look at countersteer which i plan to get next, theres "#T" on it as well. does it mean that i can only choose ones with the matching turns? i plan to get the yokomo FCD 2.0 CS if you could help me with that as well, id be appreciated. and lastly the motor, do i remove that black tubing or is it suppose to be like that? thanks! | |
07-29-2012, 08:06 PM | #12 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
Why don't you just try searching the net and reading. All of your questions have been answered at one point or another. Plus this is a crawling site not a drifting site. Not trying to give you a hard time buddy just pointing it out.
07-29-2012, 09:08 PM | #13 | |
Rock Crawler Join Date: May 2009 Location: branchville
07-29-2012, 10:17 PM | #14 |
| Re: The Person with lots of questions because im new to all of this. Please help |
07-29-2012, 10:18 PM | #15 |
| Re: The Person with lots of questions because im new to all of this. Please help i have and i tried, not that good of a luck and i am trying drifting fourms, thanks though; if you can or ecounter any results or explanations id like that
07-29-2012, 10:23 PM | #16 |
does that help<-------sarcasm like they said this is mainly a crawling forum not a drift forum. check out rctech.net they have a on road section and so does hobbytalk.com
07-29-2012, 11:02 PM | #17 | |
OfflinePlayer, reading the manuls that come with some of the parts is a great 1st step. If you don't have manuals, look them up on the Internet, then read them. Here is the spec page with links to the manuals for the Tazer.... Tazer 12T Forward/Reverse ESC | Horizon Hobby My quick look shows: 12T is the lowest # of turns on the motor, this is high speed, a higher turn motor (like a 27T) is slower but works. Don't use an 11T motor, you may fry the ESC. I would also suggest going to a 2 cell LiPO which will have the ~same voltage as a NiCD or NiMH sub-c battery pack. | |
07-30-2012, 05:31 AM | #18 | |
-so youre telling me 12 turns is fast? i thought the higher the faster :S -and as for the battery, what i got was a 7.2v NiMH 2200, idk is that what i need or not but the man who sold it to me said thats it; how long does this battery last me for a single charge? i do remember having an RC once with a similar battery, it was a 7.2v NiCd and i believe its 6 cells as well; it takes about 7 hours to charge with only 15 minutes of battery life, so im pretty scared this battery will either do the same or less. i paided 35 dollars for that NiMH one. and as for the product, under the require parts it stated 7.2v Sub-C or 7.4V Li-Po could you explain the difference? and i have a feeling the 7.4v one is better. thanks! | |
07-31-2012, 09:04 AM | #19 |
Given how little knowledge you have, and LiPo's propensity for catching fire if over-drained or incorrectly charged, I really think you should stay with NiMhs or NiCads for a while. And when you decide on a charger, make sure it's a peak charger, avoid the ones with a 15 minute timer that you turn to set.
07-31-2012, 09:34 AM | #20 |
Moved to Non-Crawlers. |
Tags |
rc drift beginner |
The Person with lots of questions because im new to all of this. Please help - Similar Threads | ||||
Lots of questions (been 20 years) | majesty9917 | Tamiya Clod Buster | 13 | 04-02-2012 03:51 PM |
lots of electronic questions | tigman250 | Electronics | 15 | 09-15-2010 07:05 AM |
I am RC dumb! Lots of questions! | wranglercheroke | Newbie General | 7 | 07-16-2009 12:57 AM |
newbie lots of questions needs answers | veewee25 | General Crawlers | 9 | 07-03-2007 07:33 PM |
hmmmm......... lots a questions | jmangone23 | General Crawlers | 5 | 08-21-2004 12:04 AM |
