10-01-2012, 07:46 PM | #1 |
| crt5 Exo clone
I decided to start my winter build a bit early. Again. Anywho, I started with a Jammin CRT.5 Pro roller kit and cut an extended chassis plate for it. Wheelbase is now 12.5". The plan is to build an Exo style buggy. Why not just buy an Exo? A couple reasons...one is that I had most of the expensive stuff already (electronics), another is that I've been beating the ever lovin' crap out of a CRT.5 ($100 shipped!) that I did a brushless conversion on for a couple months now and it has been bulletproof minus one lost screw in the front knuckle. The drivetrain is super beefy and should handle just about any motor I throw at it. Lastly, I've got the need to build something. Here's a size reference. CRT.5 on the left, Exo clone in the middle, SC10 on the right. The chassis plate is T6. I machined a shorter front shock tower, and did a little hacking on the rear tower as well. I'll more than likely cut a new one later on. Once I get the cage worked out I'll do some more shaping to make it pretty. I ditched the front upper a-arms in favor of some more solid straight links. I'll replace those with turnbuckles at some point. IIRC the stock arms are the only real weak point on these things. Leftovers! Time to start some doodling and draw out some cage work. Last edited by Duuuuuuuude; 10-01-2012 at 07:49 PM. |
10-02-2012, 08:45 AM | #2 |
Pebble Pounder Join Date: Jul 2009 Location: Suomi Finland PERKELE !
| Re: crt5 Exo clone
That Chassis looks beefy but plastic braces are more for looks than function so if Your going to beat the Cr@p out of that buggy make a top plate to be on a safe side. If You can find Bart's Parts SCRT-10 aluminium front arms they're well worth the price.
10-02-2012, 09:54 AM | #3 |
| Re: crt5 Exo clone
I plan on making a top brace to help tie it all together. I'm not a fan of aluminum arms....had too many bad experiences with my old Tmaxx. Plastic is fantastic. Having said that, I've got something special in mind for the rear arms IF I can pull it off.
10-02-2012, 05:16 PM | #4 |
| Re: crt5 Exo clone
Woohoo! I didn't screw up! Much! I didn't like that the shocks would be behind the axle and the rear shock tower had to be so tall. I could have taken the easy route and made a little bracket to move them forward, but I thought I could do better than that, so I spent the better part of the day making these... Still not quite done yet...need to find the proper drill for the pins, clean a few spots up, and round some corners off, but I think they'll do the trick. |
10-03-2012, 05:46 AM | #5 |
| Re: crt5 Exo clone
Niiice ! I've never broken a front arm on my SCRT's, I had an impression that rear arms break if i don't use captured hinge pins with uprights but I've only snapped one from where the swaybar attaches, still got captured pins for my basher. |
10-15-2012, 03:51 PM | #6 |
| Re: crt5 Exo clone
I've managed to make a little progress. I also tore apart a friends scrt to test fit the center dogbones, which do fit, so I'll have to add them to my list of parts to pick up. I also found out that I could buy an entire SCRT roller, factory fresh, for about $100 and had all of the parts I still need to buy for this CRT5. Poo. Anyway, got the arms on, though they still need a bit of finish work, and got the new rear shock tower on as well. It too needs more fleshing out and finish work, but I'll save that until I'm done with the cage, which I gathered materials for today while I was out running errands. I also learned that you should not try to cut hard anodized parts with a bandsaw. For my efforts, I was rewarded with a small shower of sparks as the anodizing ground all of the teeth from the blade. |
10-16-2012, 01:06 AM | #7 |
| Re: crt5 Exo clone
Rear end looks SOLID Is that a Shop deal ? That's great source for spareparts, chassis plate and diffs alone make more than that ! |
10-16-2012, 09:40 AM | #8 | |
| Re: crt5 Exo clone Quote:
And yeah, its awesome for spare parts. | |
10-16-2012, 02:38 PM | #9 |
Quarry Creeper Join Date: Jan 2011 Location: Kyle TX
| Re: crt5 Exo clone
Yes, that is from the warehouse. Everything is the same as the CRT.5 but the chassis and center shafts. Are you still using the dish wheels on your CRT? I'm searching for something better looking. Something that won't look huge on that short chassis. Or just spend $40 and get the SCRT chassis and shafts. |
10-16-2012, 03:28 PM | #10 | |
This rig will get sc wheels and tires. The dish wheels are sitting in a box. The other CRT5 that I bash runs 2.2 wheels and buggy tires. Bigger than stock but not goofy looking. | |
10-16-2012, 04:41 PM | #11 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
| Re: crt5 Exo clone
looks really good! i bet i know what ESC is going in that! also, does anyone have a link to that scrt deal?
10-16-2012, 10:18 PM | #12 |
| Re: crt5 Exo clone Well yeah, I'd be in trouble if I didn't. I've finally made it to the fun part of the build....tubework! I decided to try something different this time around to keep things as clean and neat as possible. Basically I brazed in some solid 1/8" rod into the brake line, then drilled and tapped it for 3mm screws. Now all of my uprights bolt right onto the plate using flush mount screws. And...a rough to-scale sketch of the design. Its in pencil and more or less acts like a work mat on my bench, so its always getting revised and tweaked. I've already changed things up twice since I took this pic last night. |
10-16-2012, 10:39 PM | #13 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
| Re: crt5 Exo clone
so you like having your hands on tube huh? (snickers) Is it even cold there yet? it was 80 here in Albuquerque today. Nice "winter" build so far. |
10-16-2012, 10:54 PM | #14 | |
We had a couple night near freezing, then back up to the 80's during the day. Awesome fall weather. | |
10-17-2012, 01:07 PM | #15 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Re: crt5 Exo clone
Hey, you actually have RC skillz! I didn't think you ever left CC J/K rig looks good, especially the rear arms |
10-17-2012, 05:58 PM | #16 |
| Re: crt5 Exo clone |
10-18-2012, 11:29 PM | #17 | |
Pebble Pounder Join Date: Aug 2012 Location: Baltimore
10-18-2012, 11:43 PM | #18 |
Pebble Pounder Join Date: Aug 2012 Location: Reno NV/ Palm Coast FL
Very cool
10-19-2012, 08:21 PM | #19 |
| Re: crt5 Exo clone
A little more progress. I'm not happy with a couple of the bends, but everything in front of the shock tower is cosmetic anyway so it doesn't matter much. I decided to retain the stock bumper because it will bounce back when I lawn dart it or hit nose first into the face of the big doubles at the track. Speaking of track, I slapped some sc wheels with Calibers on them last night after the races and tossed the CRT5 out to see how it'd do. The thing was just brutal in the straights, but the good grip and short wheelbase made for some really slow corners. And it looked a bit silly. But it was fun, so who cares. Last edited by Duuuuuuuude; 10-19-2012 at 08:24 PM. |
10-20-2012, 05:34 PM | #20 |
| Re: crt5 Exo clone
Its starting to look like something. I'm excited! |
crt5 Exo clone - Similar Threads | ||||
EXO Video Series: Build the EXO Page by page | FastEddy | Non Crawler RC's | 14 | 05-08-2012 09:45 AM |
clone of chinos fj | Nick Slemp | 2.2 Scale Rigs | 12 | 06-17-2010 12:38 PM |
Skyjacker JK Clone | bigdodge88 | 1.9 Scale Rigs | 103 | 03-11-2009 02:19 PM |
Looking to clone my Tj | 97TjZack | Newbie General | 1 | 08-25-2007 11:40 AM |
