Go Back   RCCrawler Forums > Miscellaneous > Non Crawler RC's
Thread: Want 8.4v to steering servo - 7.4v to other servos
Old 12-16-2022, 05:55 PM   #1
Default Want 8.4v to steering servo - 7.4v to other servos
I am new to the idea of using external BECs.
I have swapped the steering servo on my Fireteam. I would like to give it 8.4v and have the other electronics run at 7.4v from the ESC.
I have found an external BEC, Hobbywing UBEC 10a, and I wonder if it will work. And if so, how?!
VanCityCrawler is offline   Reply With Quote
Old 12-16-2022, 06:09 PM   #2
Default Re: Want 8.4v to steering servo - 7.4v to other servos
Basically you’d wire the BEC into the power wires going to the ESC, which would power the BEC straight from the battery. From there you’d need make or buy a bypass adapter for your servo which will have 3 servo plugs on it. One plug with power and ground that comes from the output on the BEC; one with ground and signal that goes to the receiver; and one with power, ground, and signal that goes to the servo. The bypass adapter would let your servo run at 8.4v without also sending that voltage to your receiver. Alternatively you could get a small 2s battery with the proper connector, and use the bypass adapter on that, which would save you the ESC wiring, but take up a bit more space.
DirtMerchant is offline   Reply With Quote
Old 12-16-2022, 06:44 PM   #3
ah ha!
I actually understand what you are talking about! This sounds like it would work.
I think I will have to map it out on paper to make sure I get it right.
Old 12-16-2022, 09:03 PM   #4
Excellent! I’m glad I could help. If you want to see a bypass adapter you can check out the Holmes Hobbies website and look under wiring in the electronics menu. Good luck! And be sure to double check the wiring before putting power to it, just in case.
Old 12-16-2022, 11:25 PM   #5
I almost always go to the Holmes Hobbies site and look at their bypass adapters when I make my own. One of the images is the wiring diagram which is also super useful in understanding it.
HumboldtEF is offline   Reply With Quote
Want 8.4v to steering servo - 7.4v to other servos - Similar Threads
Steering servos harry22 Losi Mini-Rock Crawler 8 05-06-2009 01:59 PM
Steering servos dirttrackdemon93 Tamiya Clod Buster 18 12-19-2008 11:21 AM
steering servos? emaxxjeremy Electronics 10 10-12-2006 12:21 AM
steering servos? emaxxjeremy Electronics 6 07-08-2006 09:57 PM
steering servos max to crawl Electronics 8 04-23-2006 07:18 PM
