Go Back   RCCrawler.com Bulletin Board > Miscellaneous > Non Crawler RC's
Thread: Tinkering with an engine
Old 09-13-2006, 06:19 PM   #1
Default Tinkering with an engine
Little update on what I'm up to:
One of our clubmembers approached me to do some work on an engine he bought. It's a 2.5 Cu/In weedeater engine, which originally ran on gas. He wanted it converted to nitro and in general produce a bit more power.
I started with cutting of the top of the heads and replacing them with new head-buttons with a higher compression ratio. Next I made a new heatsink which fits over both the cilinders. I ordered a couple of Walbro alcohol carburettors for which I made some tuned intake manifolds.
We hope to do a try-out this saturday. When all goes according to plan, the next thing to do is add a couple of custom made tuned pipes, and just to see if it works, this:
Here's what it looks like now:
Micropuller is offline   Reply With Quote
Old 09-13-2006, 06:25 PM   #2
wow. you really need to get into crawling, i bet you could make everything yourself!
trickedoutTLT06 is offline   Reply With Quote
Old 09-13-2006, 06:28 PM   #3
are you going to put the rc nos on it? that thing would be sweet in a sleeper
skidooguymxz550 is offline   Reply With Quote
Old 09-13-2006, 06:37 PM   #4
That kinda reminds me of one of Bob Shores engines. You may want to go with a bigger flywheel.
xjman is offline   Reply With Quote
Old 09-19-2006, 05:34 PM   #5
The test run went OK. I got about 7800RpM with a 20x10" prop, which equals about 5.5HP (stock was 3.2HP@8500RpM)
Here's a short vid of it running: http://home.hetnet.nl/~cyril-wichers/images/Robin5.wmv
Old 09-19-2006, 05:41 PM   #6
AKA TOKEN
ColquittCustom405's Avatar
Sweet work man.
ColquittCustom405 is offline   Reply With Quote
Old 09-19-2006, 05:42 PM   #7
Tune pipes will almost double the the HP on that engine. You have to have BP to get power.
Cole82 is offline   Reply With Quote
Old 09-19-2006, 05:44 PM   #8
Are you putting it in a car or truck?
Old 09-19-2006, 05:47 PM   #9
Is the prop just for testing the engine or is it going in a plane. Either way nice work, that thing is sweet.
TMXONR is offline   Reply With Quote
Old 09-19-2006, 05:54 PM   #10
Gold Star Baby!
very nice...Id love to have one of those in a MHZ cat hull.......crazy how all the cool large scale boat stuff comes from europe.....
NorCal 2500HD is offline   Reply With Quote
Old 09-19-2006, 06:42 PM   #11
Yep, tuned pipes are next on the list. I just needed to see how the engine performs under load, so I can do the calculations (I make my own pipes) Double the HP is a bit on the high side IMO, but a gain of 20-30% should be possible. And then ofcourse, there's the nitrous...
When all the modifications are done and I'm satisfied with the performance, this engine will -ofcourse- go into a puller!
Old 09-19-2006, 07:30 PM   #12
If you are using it on the ground I would go with a heavier flywheel, itll help keep rpms up and a more constant rpm. Have you decided what type of axle that is going to attach to? Will the crank hold up to the strain of a puller? I really would like to see this thing go once its together.
Old 09-20-2006, 09:19 AM   #13
Location: orange county n.y. , building the hydro crawler
I thought this was a nitro motor! Lets get some bigger jets and nitromethane.
92% nitro 8% 2 stroke oil if you have spare parts that is a supercharger on that would be rad.
Anyways sweet build keep us posted
sambmx is offline   Reply With Quote
Old 09-23-2006, 03:46 PM   #14
New test-session tomorrow:
Old 09-23-2006, 10:14 PM   #15
I'm a stupid C U N T!
slobin3d's Avatar
that has to be the coolest thing ive seen in a long while. What size prop is that? any ideas of what kindof power this thing is going to make
slobin3d is offline   Reply With Quote
Old 09-23-2006, 10:34 PM   #16
He said further up in the thread. Its producing 5.5 hp, with the tuned pipe a few more ponies will be unleashed. I'm still interested how the internal parts hold up to the added strain.
