Go Back   RCCrawler.com Bulletin Board > Miscellaneous > Non Crawler RC's
Thread: Novak XRS ESC question
Old 10-28-2006, 09:41 PM   #1
Default Novak XRS ESC question
Since it isn't for crawling I will put this in chit chat...
Anyone use a XRS with a 17 turn mod motor in a stampede or similar?
I have one here and I can free up another super rooster if the XRS will actually run a 15 turn like it says.
I'm just afraid the tiny thing can't actually handle it.
Thanks!
Unholy is offline   Reply With Quote
Old 10-28-2006, 09:45 PM   #2
OCCUPY RCC!
dezfan's Avatar
Just do it!:-P
dezfan is offline   Reply With Quote
Old 10-28-2006, 10:14 PM   #3
Mayor of Bedrock
freetimecrawler's Avatar
I ran mine with a 9 turn in a puller. I still use it in my rc 10 with a 12t.
Holding up just fine.
freetimecrawler is online now   Reply With Quote
Old 10-28-2006, 11:13 PM   #4
yeah on my drag car i had the xrs running a 9t but it wasent like i was racing thw whole time like a basher car would i was running a scale 1/4 mile
and ive used the same xrs with 16t mod motor for my old stampede ran it for month no problems
smokinubyrc is offline   Reply With Quote
Old 10-29-2006, 08:38 PM   #5
I run an XRS for extended periods of time on a 15t machine wound mod motor.
Crawlerguy851 is offline   Reply With Quote
Old 10-29-2006, 08:42 PM   #6
Yeah... based on everyone's experience who posted (except dez )
I went ahead and mounted it up... working great so far...
gets hot as hell but hasn't shut down or anything.
Old 10-29-2006, 08:49 PM   #7
I ran mine in my old Stampede before. I was running with a 17-turn mod motor, and had to run with a 17T pinion gear. Any higher pinion gear, and the motor, as well as the XRS casing< would start to get real warm. ;)
XXWoodmanXX is offline   Reply With Quote
Old 10-29-2006, 08:51 PM   #8
OCCUPY RCC!
dezfan's Avatar
I told you it would work!
Old 10-29-2006, 11:30 PM   #9
that was tipical on mine even with a 75 lathe the thing got hot enough i couldent touch it :-(
