Go Back   RCCrawler Forums > Miscellaneous > Non Crawler RC's
Thread: Farm Tractor build
Old 07-20-2015, 07:31 PM   #61
Default Re: Farm Tractor build
Originally Posted by ScGRaceR View Post
house mods + insane one of a kind build. loving this thread!
Thanks
Originally Posted by dr frankenstyle View Post
Awesome work !! Love all the brass-work. Are you a cabinet-maker? I was for a few years and those tools look kinda familiar . I'm major envious of that lathe, I've wanted one for years too. A drill-press is great, but .... anyway.
Looking forward to more of this build. Kudos
Than you Sir, no Im not a cabinet maker this was my first try at building any kind of cabinet, im using the garage as a test/ practice for building a window seat and entertainment cabinet for the living room. A lot to learn , but im loving the lathe so far!
Originally Posted by waka789 View Post
Awesome build subbed
thanks
Originally Posted by twodollarbill View Post
Great build. I was expecting a retro-fit of the toy tractor parts but was pleasantly surprised to see a full scratch-build. Amazing.
It must be so satisfying to finally be able to turn your own custom parts.
I do plan to use the cab, wheels and tires from the toy all will be modified a bit to work.
rcjeepbuilder is offline   Reply With Quote
Old 07-20-2015, 08:09 PM   #62
And a small update
Added a step to each of the inner axle tubes it will hold a bearing for support at the wheel.
Im not sure if I will use the HPI reduction unit but it does look cool on there!
Old 07-28-2015, 04:12 PM   #63
amazing work ,have you figured out the difference in the gearing to match tire size ?
fullsizecrawler is offline   Reply With Quote
Old 08-09-2015, 08:23 AM   #64
Thanks, No I never did any calculations but im sure it will be geared low enough with the R2.
I started making the outer axle housings
Old 08-10-2015, 06:59 AM   #65
Old 08-11-2015, 09:08 PM   #66
still need to add a bearing to the inside of the axle tubes and drill the mounting holes in the outer flange.
Old 08-12-2015, 01:59 PM   #67
finished the outer axle housings and built one wheel hub.
Old 08-12-2015, 06:49 PM   #68
I tell ya, at the rate im going I may be done with this by the end of the week........Well at least next year lol
Old 08-21-2015, 06:12 AM   #69
getting closer to roller status!
Old 08-26-2015, 08:26 PM   #70
Ok started working on the front wheel as I have now finished up the rear aside from a few set screws.
Im going to use some RC4WD hex adapters from a set of steel wheels and then make some adapters that they will bolt to then both pieces will bolt to the wheels. I will then make a axle nut that looks like the 1:1's hub.
anyways onto the pics
had to remove all the webbing
after using the milling bit on it
cleaned up the outside of the wheel as well
Old 08-26-2015, 08:29 PM   #71
I cant wait to start on the rear panel it will have a hitch for a trailer as well as a 3 point. On the other hand I can wait to start on the hydraulics, Im kinda at a loss on them????
Old 08-30-2015, 07:43 AM   #72
Finished the front wheel hubs and mounted the wheels up man its getting close to a test run! I just need to raise the front axle up and make a front driveshaft and steering then its a runner.
This thing will be so much fun to run!
I have been thinking about using the Fergelli actuators but the square bodies are making it hard for me to pull the trigger. If anyone has any of the small Fergelli's and are interested in parting with them please get ahold of me.
Thanks for looking I hope to have you all a video soon!
Old 08-30-2015, 07:56 AM   #73
Location: Taylors Falls just hanging with the MNRCRC crew.
Really starting to take shape it's a intriguing build and it will be fun watching its completion.
Stormin2u is offline   Reply With Quote
Old 11-01-2015, 05:47 PM   #74
I would really like to see an update on this, as well as more information on what that rear-end is and where one could be gotten. I have been wanting to build a 1/10 scale representation of the garden-sized 1971 Cub Cadet I own, but haven't even bothered to try yet because I have no idea what to use for motor, gearbox, and differential, and yes, I want to have a diff in it . . .
DieCastoms
DieCastoms is offline   Reply With Quote
Old 11-03-2015, 03:04 PM   #75
holy santa clause shit.... this is amazing, nice work my friend!
DirtyChevy45 is offline   Reply With Quote
Old 11-04-2015, 05:25 PM   #76
I really like the bucket did you use braising rod or like silver solder ?
Very nice I'd like to build
The reson I ask is I'm an exavator operator
And I'd like to build a couple of them then
Mabe I'll try to build an exavator lol
Kx450 is offline   Reply With Quote
Old 11-08-2015, 03:48 AM   #77
Wish I could build rc's like you draw "thoughts"!!!
LMallette is offline   Reply With Quote
Old 12-14-2015, 08:57 AM   #78
Subscribed,can't wait to see it loading dirt!
WranglerMan is offline   Reply With Quote
Old 01-24-2016, 04:25 PM   #79
Any updates??
Sent from my LG-D800 using Tapatalk
mwe-maxxowner is offline   Reply With Quote
Old 02-18-2016, 08:04 PM   #80
DieCastoms
The rear end is from a Revo and they are on Ebay real cheap.
Silver solder and brass
Thanks
Thanks
Thanks
Same here
Originally Posted by mwe-maxxowner View Post
Any updates??
No updates, I have been trying to figure out what to do for the cylinders. If work picks up again I will just pull the trigger and go with full hydro.
Farm Tractor build - Similar Threads
Wes's 1.9 Scaler Farm Truck Build WesTX 1.9 Scale Rigs 18 12-04-2014 07:52 PM
ScaleReady's Flatbed Hilux farm truck build ScaleReady 1.5 Scale Rigs 11 05-14-2013 10:32 PM
F O R D Farm Truck Build mud-sweat-gears 1.9 Scale Rigs 92 11-05-2012 02:45 PM
King of the Farm race truck build jetboat HPI Wheely King 21 06-06-2010 08:18 PM
Articulating? like a farm tractor. floogldood General Crawlers 10 12-19-2005 10:13 PM
