06-06-2017, 12:33 PM | #41 | ||
| Re: Jato The Mudboss - Dirt Oval Racing Quote:
It's not that simple to make money. There's thousands of people designing RC parts. Plus, Shapeways is not cheap so it's difficult to design things that will be reasonably priced while still giving you profit. If you have your own commercial grade printer then you cut out the expensive middle man. Or you could be like 95%+ of the "companies" selling 3D printed parts that make and sell low resolution garbage. Quote:
The second time around I put the bladders on the shock and just pushed the caps down harder. I was being a girly man because I was afraid to wreck the bladders. Your instructions are simple and the same basic steps as any shock building guide. It's never that easy for me. I fill the shock bodies so that there's a slight overflow. I then push the bladders on. I can do this twenty times and the shocks will rebound twenty different amounts. That's the parts that I can't ever seem to get right. | ||
06-07-2017, 05:21 AM | #42 | |
Quarry Creeper Join Date: Aug 2014 Location: home
Repeat for the front...it's pretty messy! Sent from my LGAS375 using Tapatalk | |
06-11-2017, 07:49 PM | #43 |
I got my custom wrapped Mudboss body. Unfortunately, it had shipping damage. He shipped the wrapped paints jammed together in a padded envelope. I hate that common sense is a dying skill. Of course the panels rubbed together and gouged the side panels. He also messed up the left side of the body. The #2 and the bull are skewed forward for some odd reason. He said he would fix the body if I mailed it back to him, but he couldn't guarantee that I'd have it back in two weeks for the next race. What kind of customer service is that? So I asked him to print the vinyl and send it to me and I'd install it myself. For now, here is the body assembled and installed. I think everything is ready and I will be racing next Sunday unless something changes. I'm also having some issues with the truck. All of the wheels spin true except the left front. It's badly warped. The aluminum "upgraded" bellcrank also has lots of play. Traxxas is being difficult in standing good for it so we will see what happens. |
06-11-2017, 08:19 PM | #44 |
Quarry Creeper Join Date: Aug 2014 Location: Orange County
Looks good. Do you have to run the stock slash tires or can you change them? Sent from my SM-G920T using Tapatalk |
06-12-2017, 06:53 AM | #45 | |
Yes, in the stock class you have to run your choice of the stock Slash tires (BFG, Kumho, or Traxxas treads). You can't use these in the S1 compound. Once you move up to 13.5T you can also run the Duratrax Bandito tires. In the mod class you can run any tire. These are the rules at my truck anyway. | |
06-12-2017, 08:23 AM | #46 | |
06-12-2017, 08:37 AM | #47 | |
Why do you say the Traxxas rims aren't good for racing - because of the weight? | |
06-12-2017, 08:43 AM | #48 | |
Yes all the rims say 3.0/2.2 but that's only tire mounting specs...not a chopped up wheel Sent from my LGAS375 using Tapatalk | |
06-12-2017, 08:43 AM | #49 | |
Sent from my SM-G920T using Tapatalk | |
06-12-2017, 08:50 AM | #50 | |
*disclaimer: this is an rc4wd wheels but it has the same basic shape as a traxxas wheel. Sent from my SM-G920T using Tapatalk | |
06-12-2017, 10:20 AM | #51 |
I see what you mean now. I do have some Borrego wheels on which I'm going to put Bandito tires. I'm sure I'll either move up to 13.5T or just build another car. But since stock foams are required in the stock class I don't see any benefit of using a different wheel as far as the foams go.
06-12-2017, 10:28 AM | #52 |
I just remembered. Another wheel to look at is the jconcepts Hazard as I'm pretty sure they make an insert similar to what you did to make it a dish wheel. Sent from my SM-G920T using Tapatalk |
06-12-2017, 10:40 AM | #53 | |
I double checked the rules and I can use any wheel, but the foams must be whatever comes with the tires. | |
06-13-2017, 08:29 PM | #54 |
I was quite annoyed when I bought an "air cleaner" online and it turned out to be a juice bottle cap with some chrome wrap on the top. I was so annoyed, in fact, that I designed and printed my own. I'm biased, but I think mine looks much better. |
06-19-2017, 06:34 AM | #55 |
I finally had a chance to race my Mudboss this weekend. I started with something close to the Mudboss suggested setup for a loose track. I'm not a fan of that setup at all. In practice I could not get my car to turn unless I slowed down a lot for the turn and I was off the throttle or at least only using partial throttle. Because of this I started getting hard on the brakes into the turn to get the rear end to slide out. I spun out a lot learning this. After some tweaks the car seemed better, but I still wasn't happy with it. In the first heat I started 9th out of 10 and finished 4th. Not bad considering it was my first time out with the car and I wasn't happy with the way it was handling. I made some more tweaks before the second heat. The car seemed to get worse. The severe push had returned so I resorted to braking hard again. I spun out a lot trying to slide the car because it simply wouldn't turn any other way. I finished 4th out of 4. With those results I didn't make the A Main. I made some more changes before the B main. I am not a setup guy. I typically setup a car and learn to drive it. I told myself to just drive the car that way it had to be driven in the main. I decided I was going to brake before the turn, get slow for the turn, and drive out hard. I also decided I was going to brake on the straight so I didn't spin out in the turn. I pushed hard, tried to stay focused (difficult for me), and tried to stay consistent. I started in 3rd and about 10 laps or so into the race I took the lead and never looked back. I was happy with a B Main win for my first outing. I got bumped up to the A Main where I started 6th out of 7th and that's where I finished. My new battery didn't seem to have any pep. I need to try to get the car to turn. Before the main I put a larger spring spacer on the left rear shock and the next smaller sizes on the right rear shock. I was thinking this would lean the car forward and put more weight on the front wheels while also putting more weight on the right rear tire. I think it helped a little, but not as much as I wanted. What suggestions do you guys have for getting the car to turn better? Thanks. |
06-19-2017, 06:59 AM | #56 |
Limiters...and you're on the right track with rake...losi springs. typically you lower the left not raise it...ball diff(never tried one but always knew that's what i needed) i drove with a spool...should have gotten a ball diff instead Sent from my LGAS375 using Tapatalk Last edited by kongluc; 06-19-2017 at 07:03 AM. Reason: Edit |
06-19-2017, 07:08 AM | #57 | |
In stock Mudboss you can't change the springs or diff or anything like that. In real oval racing cars typically lean inside because of tire stagger and setup. You can't stagger Mudboss tires so from what I've read so far people get the car to turn by raising the left side of the car which puts more traction on the outside rear tire. | |
06-19-2017, 07:23 AM | #58 | |
If you jack up the left and lean it to the right where....is the traction for the left to keep forward momentum? Just losing a lot of "traction" there is a difference between traction and grip...you got too much grip and not enough traction....the higher up in the classes you go you'll understand... Sent from my LGAS375 using Tapatalk | |
06-19-2017, 07:29 AM | #59 | |
Stand the right rear shock up, lay the left in? Drop oil weight in the right rear and let it squat on throttle to the right rear? Play with your roll centers and camber changes? Never ran a mud buss on the dirt but being an oval guy for years theres lots of things I could think of to make a car turn besides jacking the weight to the right. Any pictures of the track? Mudbuss? Is it loose or clay track? | |
06-19-2017, 07:37 AM | #60 | ||
I don't have any photos of the track offhand, but here are two videos of it. I am not in either of these races. https://www.youtube.com/watch?v=HSMojEz4wqA https://www.youtube.com/watch?v=fUtMnnG-LWU&t=102s | ||
Jato The Mudboss - Dirt Oval Racing - Similar Threads | ||||
Dirt Oval Mudboss Racing | JatoTheRipper | Non Crawler RC's | 5 | 05-01-2017 12:09 PM |
Dirt Oval? | flapjack | Colorado | 4 | 07-05-2010 07:09 AM |
Dirt Oval ? | twisted | Non Crawler RC's | 2 | 11-20-2008 11:55 AM |
