01-12-2019, 08:28 PM | #1 |
RCC Addict Join Date: Dec 2007 Location: (LES) Manhattan, New York
| RC10DS - Pantera - Mid Engine Dual Conversion Hi Everyone. Here is a thread on a project i started in December 2017. During the holidays I found a RC10 mid engine buggy conversion. Mind you, im not a buggy guy. It was a nice, clean and simple design with a few custom parts like the chassis. Custom because the gear box was reversed and new mounting holes were needed. There is also an added motor brace. I had the urge to buy it, but again, im not a buggy guy. then i had a thought ...hey, why not get it and convert the conversion to a DS ? I pulled the trigger and made the purchase. The buggy was in the mail The RC10DS - Mid Engine Dual Conversion project is born This is the mid engine RC10 buggy I got some front end DS parts ready as you can see Gathering some more parts.. I Got the DS nose plate mounted but im not liking the steering linkage setup that came with this buggy. Im going to be replacing it with stock DS parts. Front is taking shape...rear still in buggy form Steering setup replaced with an original DS setup. I'll be replacing most of the tierod ends with RPM versions. [ Rear end of buggy getting converted Front and rear ends looking good DS Shocks and front bumper mounted [ The buggy had a custom support brace to secure the steering post and support the nose tubes. It was specific to the buggy and could not be used for the DS. Instead i used the buggy nose tubes and mounted them onto a set of aluminum blue anodized GT nose tube braces. So this is where im at as far as the chassis. The nose tube braces are not secured to the chassis yet. I was trying to avoid the chassis trimming by using axle adapter to reduce wheelbase...but i only manage to reduce it by 1/8 inch. This was not enough as the HPI Pantera body has a 10in wheelbase. I did some measuring and pulled out my cutting disk equipped Dremel. I cut a little over 1/4inch and drilled new nose plate and servo mounting holes. This granted me the 10 inch wheelbase i need so that i can mount the body i wanted from the beginning, The Pantera, and use the original DS wheels. This also placed the nose tube supports further back. This and reversing the supports will place the needed mounting holes closer to the inside of the chassis for added strength. The only thing left is to order a low profile steering servo, install motor/ESC, paint and mount the body. The bottom side of the front end of the chassis The bottom side after trimming and drilling of new mounting holes The rear wheel well and tire. Notice the center wheel dimple on the lexan and the axle....cant get any closer than that The front wheel well and tire. near perfection! A few more pics The Finished Front End I purchased a HiTEC low profile servo to clear the nose tube braces as well as reverse the left with the right so they sit on the inside of the tube rather than the outside. 4 holes were drilled onto the chassis and the braces were mounted. The rear tail light panel/ trunk has been attached to the HPI Pantera body via 4 button head screws. The body is ready for paint. Paint in Progress No Wing Mocked Wing Completed Car minus motor/esc & radio gear. I was not sure about painting the car green but after a few layers I ended up liking it a lot. The green has slight gold hues at different angles. Last edited by Lobonyc; 01-13-2019 at 09:23 AM. |
01-12-2019, 08:53 PM | #2 |
Pebble Pounder Join Date: Mar 2007 Location: Northern Ontario
| Re: RC10DS - Pantera - Mid Engine Dual Conversion
So clean. I like. What body are you going to run on it? |
01-13-2019, 09:36 AM | #3 |
| Re: RC10DS - Pantera - Mid Engine Dual Conversion |
01-13-2019, 10:01 AM | #4 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Good to see you still involved my friend And again... I’m jealous of your attention to details and using old rc models. Nice color choice as well More? |
01-13-2019, 11:26 AM | #5 | |
| Re: RC10DS - Pantera - Mid Engine Dual Conversion Quote:
Yep, the RC10DS is an old model. The electric DS were produced in 1996 and the Nitro in 1997. Im glad i managed to stock up on spare parts through the years. More? If you meant with this project then Yes. i need to equip the Pantera with a brushless motor/ESC combo and a reciever. Then she can be complete. If you meant, more RC10DS projects? Then Yes, I have a few DS cars im working on. | |
01-13-2019, 04:30 PM | #6 |
I always loved the old DS chassis - I had a couple RC10T2 back in the day, was planning on converting one of them but things didn't work out - fantastic to see such a great job done on one! That thing looks wicked... |
01-13-2019, 06:44 PM | #7 |
| Re: RC10DS - Pantera - Mid Engine Dual Conversion Thanks man, i got one DS and got the fever for that particular model.
01-14-2019, 10:20 AM | #8 |
You know Alex...I may have to break out my old chassis (x2) and strip one down like you did...the more I see your silver polished builds the more I like them. You are the go to guy for old school RC10 reference.... Glad to see all the old photos re-imerging as well....I lost most of mine with the photo bucket debacle Tapatalk....hard to find the thread you want is my only complaint there Great to see all the builds again....especially “Pinky”. |
01-15-2019, 10:38 AM | #9 | |
01-15-2019, 10:43 AM | #10 |
Oh man.... You don’t want to know what i’ve done to the wreckluce |
01-17-2019, 05:27 PM | #11 | |
Was it major chassis reconstruction? Does it still resemble the original wreckluse chassis? I still have mine. I cant believe i got this chassis back on Christmas 2009. It took a while to get the shocks and links just right but im crazy happy with the outcome. | |
01-18-2019, 11:02 AM | #12 |
Yes! I chopped it, I cut it, I slammed it I put a monster motor in it. I haven’t updated the thread yet....i’ve been lacking in the photo area lately |
01-18-2019, 06:11 PM | #13 |
01-19-2019, 09:46 AM | #14 |
01-26-2019, 02:18 PM | #15 |
02-14-2019, 01:27 PM | #16 |
Rock Stacker Join Date: Feb 2019 Location: Modesto
That thing is cool. I grew up with Associated, "Since 1993 with an RC10T". I've often debated doing a DS build with the "parts-car" I have for my old RC10T. That's right... I still have the RC that got me into the hobby and I still run it. |
RC10DS - Pantera - Mid Engine Dual Conversion - Similar Threads | ||||
C8 Mid Engine Corvette | STANG KILLA SS | Chit Chat | 138 | 09-02-2021 11:34 AM |
Mid engine class 3 buggy | holycaveman | 2.2 Scale Rigs | 167 | 04-08-2015 03:40 AM |
Any mid engine IFS or solid front axle rigs? | arthurc10 | General Scale Talk | 2 | 01-21-2015 09:51 PM |
Electric to a engine conversion help!!!! | fordlightning + jeep | General Crawlers | 7 | 12-22-2012 02:05 PM |
dual engine wk? | spiff2022 | HPI Wheely King | 14 | 02-22-2008 02:26 PM |
