02-18-2007, 07:34 PM | #1 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
| how much power can a pede really handle??
whats the most amout of motor and vltage can i push through a pede, IE mamba maxx and 7700 or velocity 4.5
02-18-2007, 07:41 PM | #2 |
Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
If you are going to put alot of power throught one, you will need at least the upgrade gears from Traxxas (alum idler, delrin top gear), and either CVD's or the Steel Output yokes for the sliders. The stock plastic yokes wont last verry long with all the power.
02-18-2007, 08:05 PM | #3 | |
Pebble Pounder Join Date: Dec 2004 Location: Medina, Ohio
02-18-2007, 08:14 PM | #4 |
Quarry Creeper Join Date: Nov 2004 Location: In the saddle...
Check rc-monster.com for tranny upgrades. I'd recommend the aluminum/steel differential http://www.rc-monster.com/proddetail...onentspedediff , as well as an aluminum idler gear. Steel yokes are a must, or go to MIP CVD's. I'd do an RPM gear cover and hub carriers as well. I have a full FLM 'pede running a Mamba Max 7700kv motor. I'm definitely going back to RPM knuckles and arms for durability. I have the steel differential and have found that it increases durability but adds a significant amount of rotating mass. I kept having issues with balooning tires. They turn into pizza cutters when you corner, so I'm currently switching over to 17mm buggy rims and tires. |
02-18-2007, 08:18 PM | #5 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
Agreed on the CVD's and the internals.If you're running that 4.5 make sure the mesh is dead on or you'll strip the spur gair-run-teeed.
02-18-2007, 08:32 PM | #6 |
O'yeah,well, we just installed 7 cells in our Pede today:-P
02-18-2007, 10:29 PM | #7 |
Pebble Pounder Join Date: Dec 2006 Location: Peoria, AZ
I have a pede with the 5.5 and never had a problem. I have the aluminum idler and steel top gear and as long as it's well greased it works fine. It's true about the plastic yokes. Those were the first to go. I did have to replace the main plastic gear which houses the spider gears but that's it so far. With the 4.5 don't even bother running the stock idler. You'll tear it to shreads in 5 minutes.
02-18-2007, 11:09 PM | #8 |
Ours is all stock and handles 7 cells great. Burns rubber BIGTIME!
02-19-2007, 10:17 AM | #9 |
Quarry Creeper Join Date: Jan 2006 Location: Jonesboro, TN
I found the limit a while back. It will handle a Novak SS 5800 or similar on 6-7 cells all day long. Once you move up to a GTB or LRP Sphere kit, you will need to add the aluminum idler gear. But you shouldn't have any more trouble on 6 cells. Then I went with a Lehner Basic 5300 on 8 cells and that was just too much. It would desinigrate the diff gear every time I did a speed run. I broke many axles too. I switched to HPI Dogbones and snapped them about the same so I tried MIP CVD's and they weren't any stronger either. The best axle combo for me was the stainless steel outdrives, stock sliders, and Street Sport axle stubs. If I have to do it again I will use Jato shafts though.
02-19-2007, 10:26 AM | #10 |
REST IN ALOHA CHIP Join Date: Nov 2005 Location: *
i think JRH has a fast lane converted pede that is pretty much indestructable, it take just about anything that he'll throw at it, it doeshave full metal intrnals though. JRH correct me if im wrong.
