12-07-2019, 02:39 PM | #61 | |
Quarry Creeper Join Date: May 2010 Location: rock hill
| Re: New Losi Mini-T 2.0 Quote:
No they do not. Sent from my iPhone using Tapatalk | |
12-07-2019, 07:10 PM | #62 |
I just spotted this Brushless motor/ESC combo. I'm a bit stunned, I've never seen an ESC crammed into motor like this! https://www.horizonhobby.com/brushle...000kv-dyns0501 Also new tires hopefully something like I was after. no pictures just a listing. They list the stock tires separately so these should be something new. https://www.horizonhobby.com/directi...-t-20-los41010 Last edited by HumboldtEF; 12-07-2019 at 07:21 PM. |
12-12-2019, 11:21 AM | #63 | |
I trust you but all I need is to install one really Maybe that brand just used a poor quality plastic? Or maybe they need a bit of heat to help them flex? I was just about to pick up a few so I could storage charge the battery with a real charger. I suppose I could just look for a charge adapter that's already soldered. | |
12-12-2019, 11:28 AM | #64 | ||
https://www.horizonhobby.com/product...2wd-p-dyns1450 Quote:
Every time I install and remove the battery on the Mini-T I'm reminded how much I hate EC's. And the plastic feels so flimsy so I'm not shocked by the troubles that svt experienced. | ||
12-12-2019, 11:34 AM | #65 |
Ok fair enough, I converted away from the EC5's for my 1/10 scales so I understand that. Time to try out some XT30's I suppose. I had a facepalm moment last night when I was looking at the hop up ad that came with the truck and that ESC/motor that I though was something new or special was right there all along, I just didn't notice it lol On the subject of the brushless motor, I'm really interested to try it out but I want these to be kid friendly, might just end up with a 3rd Mini T 2.0 so I can keep a pair that can run together. Last edited by HumboldtEF; 12-12-2019 at 11:36 AM. |
12-12-2019, 11:41 AM | #66 | |
If you just need a charge lead, you can get them premade on Amazon for cheap. | |
12-12-2019, 11:51 AM | #67 |
Okay Thanks for the feedback guys! I opened up the spur cover to check the gear mesh as it was sounding a bit off. I found its got a wobbly/off center spur and the mesh is a bit too tight. They use a hole system for meshing the gears instead of a slot. So I opened up the holes a bit so I could move the pinion farther away. The way I treat these off center spurs is to find the tight spot where the pinion binds and set the mesh in this spot. You'll likely find the mesh is good on the opposite side so I like to spin it as I check to make sure its good on all sides. Another thing I noticed was the pinion itself had a tiny wobble to it and the farther out its installed on the motor shaft the worse this wobble gets. Just to check I installed it backwards and the wobble was almost entirely gone but you cant actually run it this way. I though maybe the motor shaft got bend when I remove the set screw but its fine. |
12-12-2019, 11:55 AM | #68 | |
I've never seen a wobbly pinion. I guess the low cost is starting to show... Have any of you had failures of the A-arms? Apparently lots of people are so Losi changed them. There's more reinforcement around the hinge pin. Mine have been fine. | |
12-12-2019, 12:14 PM | #69 | |
No A arm failures though I haven't handed over to any kids yet. I had a wreck the other day and was looking at the size of the hinge pin area and it is pretty dainty. Last edited by HumboldtEF; 12-12-2019 at 12:20 PM. | |
12-14-2019, 03:02 PM | #70 |
Beefed up a arms came in today. Wish I could have got two sets cause I’m buying another 2.0 Sent from my iPhone using Tapatalk |
12-15-2019, 08:53 PM | #71 | |
Can confirm the stock A arms are not kid proof, I'd rate the strength a 10 (10 minutes) lol It cracked at the pin. I'll try a CA repair in the mean time. Quote:
Its hard to tell if this listing is for the originals or the new beefed version. https://www.horizonhobby.com/suspens...20-p-los214003 Last edited by HumboldtEF; 12-15-2019 at 09:17 PM. | |
12-17-2019, 04:50 AM | #72 | |
Sorry I don’t. They came loose in no packaging. Sent from my iPhone using Tapatalk | |
12-17-2019, 06:10 AM | #73 | |
12-27-2019, 02:47 PM | #74 |
New A-arms just showed up. Not sure if this part number is correct because the packaging was opened already. It does say rev A (revision A) so maybe it the right part number. looking at the part listed on Horizon they dont appear to be rev A, they dont have the larger ends from what I can tell. https://www.horizonhobby.com/suspens...20-p-los214003 Original on top, rev A on bottom |
12-27-2019, 02:54 PM | #75 |
Apparently the Mini-T 2.0 production was stopped or something because they are on backorder until January. I believe it's so they can update the A-arms as a running change. EDIT: Horizon's website says backorder until March! That's either going to take some wind out of the sails of this truck or the lack of supply will hype it up. I hope it's the latter. |
12-27-2019, 03:45 PM | #76 |
I saw that they are backordered I just though they had sold out or something. I guess it should be for the best so they dont have people worried about durability. |
12-27-2019, 03:59 PM | #77 |
| Re: New Losi Mini-T 2.0 It could be due to sales. It's just my assumption that they're making a running change. I have no information to back that up.
01-22-2020, 06:24 AM | #78 |
Quarry Creeper Join Date: Apr 2006 Location: 5280
| Re: New Losi Mini-T 2.0 |
01-31-2020, 10:34 PM | #79 |
Just got my dynamite brushless setup. Super clean with built in esc and very smooth. Cant tell if sensored, but there's zero cogging and low speed is excellent.
02-06-2020, 05:10 AM | #80 |
Rock Crawler Join Date: Mar 2012 Location: UK
I’ve just ordered one along with the alloy shocks, should be with me tomorrow |
New Losi Mini-T 2.0 - Similar Threads | ||||
flat irons+losi 1.9 Team Losi rims for LOSI Mini= ? | general lee | Tires and Wheels | 11 | 08-27-2009 04:08 PM |
Losi Mini LST2, Traxxas Mini Slash, or Mini revo. | CrawlinMike | Non Crawler RC's | 10 | 07-14-2009 06:53 PM |
