04-04-2020, 05:19 PM | #101 | |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
| Re: New Losi Mini-T 2.0 Quote:
Any clue what the pinion sizes are slotted for on the motor mount? Id like to get a smaller pinion. The brushless 40th is just way too fast! I see stock pinion is the middle one. But any clue what size pinion is needed for the closest mount mount holes? Thank you. | |
04-04-2020, 06:30 PM | #102 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
Those look freak'n awesome. I might have to try and get my old Mini LST up and running. |
04-04-2020, 07:10 PM | #103 | |
I have to admit, it was fun jumping an RC for a change... I had one of these way back in the day. Actually I had the mini T buggy. That thing was so much fun. But man did it break every other run. It was cool to drive one of these again though! Even cooler was how freaking fast the brushless motor combo is. Jesus. Its wheelies on demand like my aarma granite BLX brushless. Its just wheelies when you full throttle. Almost at every speed too. The radio and transmitter sucks though. Its throttle was basically all or nothing if you ask me. So I slapped a flysky GT3 into mine and I can control it SO much better. I immediately noticed. I need to get a 1/10th buggy next. I did this all wrong. 1/10th crawlers to 1/24th crawlers. Then I got an aarma granite BLX brushless and that thing could kill someone if it hit them at full speed. Its just so dam big and fast. Its too much for me. This is funner than you know what around the front of the house. In and out of my neighbors yards, off the curbs, off 6" high kids plastic jump, you name it, I just did it and it held up ok. Nothing broke in the 5-6 times I rolled it for whatever reason. And this new motor/ECS all in one motor is a trip. I ran mine a whole battery back (20-25min not WOT the whole time) and my motor was not hot by any means. I had never seen an ESC in a motor before. It seems to work pretty good. Too good actually. I will end up dropping a pinion to slow this down just a smidgen. Fun times! It rips! Jumps very well too! Last edited by BIGW0RM; 04-04-2020 at 07:25 PM. | |
04-04-2020, 09:20 PM | #104 |
Congrats! I don't know if you care about value, but if you do you may want to put that numbered chassis away for a few years. It may be worth money.
04-05-2020, 09:19 AM | #105 |
Thank you. I hear what your saying, but it’s too late now. I’ve already got a couple marks. And that’s ok with me. I don’t shelf queen anything anyhow. Sent from my iPhone using Tapatalk |
04-05-2020, 10:13 AM | #106 | |
Thats a good question, I looked through the optional parts and manual but they dont list any other pinions or event the stock pinion. | |
04-05-2020, 10:21 AM | #107 | |
http://www.losi.com/ProdInfo/Files/L...-Manual-EN.pdf It appears to be this pinion. https://www.amainhobbies.com/losi-48...454420?v=22070 I tried a 10T I had laying around and it was much easier to control, but it was maxing out the motor RPM pretty quick. Im going to try a 13T next. Im also going to order that HR motor mount with adjustable mesh. I cant stand the hole design. EDIT: That actually doesnt appear to be the pinion at all. That pinion part number shows 3.175mm hole. I believe the pinion is 2mm bore. Odd that the diagram shows a PN. Yet that looks to be for something else. Im confused. Last edited by BIGW0RM; 04-05-2020 at 10:30 AM. | |
04-05-2020, 10:28 AM | #108 | |
I have the stock motor right next to me and can confirm the motor shaft is 2mm. EDIT the part number LOS 4115 that they show as the stock pinion also brings up 1/10 scale SCT's as compatible so it must be the wrong part number Losi Last edited by HumboldtEF; 04-05-2020 at 10:33 AM. | |
04-05-2020, 01:25 PM | #109 | |
04-05-2020, 06:56 PM | #110 | |
That is interesting I didn't know that. | |
04-06-2020, 12:11 PM | #111 |
| Re: New Losi Mini-T 2.0 It was a cool find for sure. Heres the manual for the motor/ecs all in once combo on the 40th version (DYNS0501) https://www.horizonhobby.com/pdf/DYNS0501-Manual-ML.pdf I will be dropping my punch down soon. It wheelies too much out of the box. Last edited by BIGW0RM; 04-06-2020 at 12:34 PM. |
04-07-2020, 12:37 PM | #112 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
I have a LE, anyone know of chassis protector? i dont plan on driving it much, but when i do, id like to protect the chassis. |
04-07-2020, 12:59 PM | #113 | |
https://www.ebay.com/itm/Chassis-Pro...EAAOSwlSZeZb~6 For now, I used some thin rubber weather stripping stripes from front to back to keep mine from being scraped up along the chassis. | |
04-07-2020, 01:05 PM | #114 |
Yesterday I took out my Mini T that I converted to brushless and managed to smash the body up and snap off my 3d printed shock towers in the span of about 15 minutes lol. Its not like its fragile, I jumped and hit my house lol It wasnt the stock body though its the Carisma Coyote 1/18 crawler body which is apparently pretty thin. It landed on the bed and did the shock towers and body in. So I converted it back to the stock shock towers and stock body so I can actually drive it. I was driving on a tiny bit concrete and grass and I got zero wheelies, maybe its not grippy enough. Oh and I do have the LE pin tires. |
04-09-2020, 09:29 AM | #115 | |
I installed a stronger servo i had left over and had to use spacers and a normal plastic servo horn since the stock servo saver didnt fit the new servo. https://www.amazon.com/AGFrc-Sub-Mic...6444677&sr=8-8 5 mins after setting up a small jump in my somewhat soft muddy grass (or lack of) and it SNAPPED the horn right off. It immediately reminded me of how fragile the 1st version was. It also makes me somewhat question if I want to dump money into this thing for hop ups. I was thinking about buying all the aluminum upgrades. But Im worried those will bend on first impact. Its fun, but seems just as fragile as the last one. No wheelies? Mine wheelies on asphalt and even while rolling on asphalt with the 40th 6k brushless motor. In the grass its instant wheelie if I dont use throttle control. Which is hard. I just want to GO! lol. I do plan to lower the punch setting down to 1-2. Its just too much acceleration out of the hole. Last edited by BIGW0RM; 04-09-2020 at 09:38 AM. | |
04-09-2020, 10:41 AM | #116 |
Thats a bummer BIGWORM. I blame my breakage on driving late at night in a confined space and I only broke stuff I had added or modified. I did break one of the front A arms at the hinge pin early on (or my Nephew did rather) but they did come up with a new design that has a bit more meat to it (Horizon sent me replacements for free). I guess even though its tiny I might just need more space. Its hard to imagine that servo saver snapping with all the play it has, its sooo sloppy lol EDIT: I guess I miss read that, maybe the weak stock servo and sloppy servo saver are a safer fit for this thing? Last edited by HumboldtEF; 04-09-2020 at 10:45 AM. |
04-09-2020, 11:18 AM | #117 | |
Ah its my own fault. I should have left the stock servo alone. It worked. It was just sloppy and I wanted to try my left over servos form my micro crawlers. Being a crawler guy makes me not want a servo saver at all. But in this case, it seems to be a must on the mini T 2.0. I ended up putting the stock one back on and used the zip tie mod around the stock servo saver. Which actually works pretty good. It will still give some play, but not nearly as loose when just driving straight in stock form. I also ordered all 5 of kimborugh(sp) servo savers for micro servos. They where only 5 bucks each so I bought all 4 for options with all my micro servos. Lucky me, they are local to me. So I should have them soon and can put that cheap torque servo I had tried for 5 mins back on. For those who want to change out the servo and keep a saver on it, here are some options. Servo Savers :: Small Servo Savers - Kimbrough Racing Products - RC Spur Gears, Pinion Gears, Servo Savers I have no clue on the quality. But its all I could find for small servos. | |
04-11-2020, 10:23 AM | #118 |
Well, I ordered a bunch of stuff for my Mini T. Hopefully I dont bend it first run...lol. Damn quarantine has me spending money on parts to keep me busy. HR front arms: https://www.ebay.com/itm/Hot-Racing-...72.m2749.l2649 HR front spindles: https://www.ebay.com/itm/Hot-Racing-...72.m2749.l2649 Jconcepts Body: (I like the rear spoiler design. The stock one seems to rip off too easily.) https://www.ebay.com/itm/JConcepts-F...72.m2749.l2649 Losi Front pivot: https://www.amainhobbies.com/losi-mi...11001/p1144676 Losi Caster block: https://www.amainhobbies.com/losi-mi...11003/p1144678 Losi front brace: https://www.amainhobbies.com/losi-mi...11007/p1144681 Losi Front camber bar: https://www.amainhobbies.com/losi-mi...11009/p1144683 Tamiya Metalic red PS-15: https://www.ebay.com/itm/353044693141 If I could only find the steering bell crank in metal! Its out of stock everywhere. = ( Last edited by BIGW0RM; 04-11-2020 at 10:27 AM. |
04-11-2020, 02:03 PM | #119 | |
Glad I'm still able to work and have a paycheck rolling in. Sounds like it'll be a pretty stout Mini-T with those parts | |
04-12-2020, 10:30 AM | #120 | |
And thank you. Well see how it all comes together. The Mini T 2.0 is fun, but its size has me wanting something bigger now. Happy Easter! | |
New Losi Mini-T 2.0 - Similar Threads | ||||
flat irons+losi 1.9 Team Losi rims for LOSI Mini= ? | general lee | Tires and Wheels | 11 | 08-27-2009 04:08 PM |
Losi Mini LST2, Traxxas Mini Slash, or Mini revo. | CrawlinMike | Non Crawler RC's | 10 | 07-14-2009 06:53 PM |
