Go Back   RCCrawler Forums > Miscellaneous > Non Crawler RC's
Thread: M548 tracked vehicle
Old 07-24-2020, 06:41 AM   #21
Default Re: M548 tracked vehicle
I needed an idea for these "hooks" (?):
They are all over the cab,inside also. My logical way to do them was in metal but i needed a bunch. Already did ones for a 1/6 willys but were bigger and only 4 of them..
So I tried to model and 3d print them . Are a bit small but the printer handled well
Are a bit rough but sanding and paint will improve
cooper_xl is offline   Reply With Quote
Old 07-26-2020, 05:13 PM   #22
Mike Flea's Avatar
That'll work
Mike Flea is offline   Reply With Quote
Old 07-27-2020, 11:41 AM   #23
M548 carry a set of tools on the front. Sledgehammer,shovel, picaxe and axe
Started with the sledgehammer:
I think the shovel exceed my skill level...let's see
Also worked on the rear section, that small door to the cargo area
the paint will do wonders
Old 07-27-2020, 03:44 PM   #24
Mike Flea's Avatar
Looks good
Old 07-28-2020, 12:27 PM   #25
Axe done and put to work
Old 07-28-2020, 04:55 PM   #26
Mike Flea's Avatar
Don't forget the indent in the left rear lower body for the fuel fill cap.
Old 07-30-2020, 12:18 PM   #27
Don't worry, it's in the making
For now:
glued the roof and did the opening of the hatch
A splash of color to see how it looks
I have the rear lights, but they'll be painted separately. The d-ring shackles were designed by me and printed in one piece but they move freely
also got to take care of those scratches
Old 07-30-2020, 06:07 PM   #28
Mike Flea's Avatar
Roof opening turned out good, nice smooth cut in the roof
Old 08-01-2020, 03:40 AM   #29
Thanks! I think you will like what will be over that opening
Well, when the windows were cut, didn't notice that the real ones weren't square. Small detail but bothered me ...
So...
Another job was making the hooks for the canvas. Was thinking in buying those tiny hooks for bras but then, i preferred to do only to see how it could look
Old 08-05-2020, 11:35 AM   #30
small update:
Gear lever:
goes next to the dash:
Old 08-05-2020, 04:22 PM   #31
Mike Flea's Avatar
Looks good, are you going to bend it a tad to the right?
M548 tracked vehicle - Similar Threads
Urban Assault Tracked Vehicle Shape_Shifter Traxxas TRX-4 11 07-07-2019 01:03 PM
Tracked FPV Vehicle Shape_Shifter Non Crawler RC's 8 12-18-2017 07:20 AM
Tracked Vehicle Radio Help teifert2429 Electronics 13 11-26-2015 04:29 PM
Any Tracked fans out there? snydercj7 Non Crawler RC's 2 07-23-2011 09:42 AM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
