Tamiya MF-01x Revision After digging my Jimny out after discussing the ability to put the gear reduction hubs from the Monster Beetle TR and Dynahead to fit the MC-01x chassis and decided to start revising it and plan to eventually buy one of those Monster Beetle TR kits to kitbash it’s hubs from. When I first built it, the truck put silly putty in the diffs and put a 55t closed end bell motor from my Night Crawler BND (put a Traxxas Titan 21t in that) with the smallest Tamiya pinion while using a XL-5 ESC, basic Traxxas 2.4 radio and Savox waterproof servo and Duratrax 3000mAh 7.2v pack.I also used Tamiya’s red anodized aluminum sedan shocks and eventually Associated brown buggy springs, then RC4wd’s 1.55” Landry’s and Mickey-T Baja MTZ tires that are a good bit taller than the 1.9” Rally Block tires on the wheels from the Golf GTI kit that these come with. Problems I’ve run into is that when it comes to torque, that motor is gutless, especially when you factor in the NiMH pack, taller gearing via too big of a pinion and those big Mickey-T’s and had no holding capability of even the Integy 55t that is still in my crawler Wheely King has. Other issue is it spiting out the dogbones that was fixed by installing the Tamiya Double Cardan CVDs, then tire clearance without jacking the body to the moon, I did trim the openings and front bumper for now that will help with body clearance, at least. Here’s a few pics starting with before setting it aside out of frustration. https://hosting.photobucket.com/albu...ps1mfvczgr.jpg https://hosting.photobucket.com/albu...ps5cdakpja.jpg And a couple after dragging it out with bowed rear body posts https://hosting.photobucket.com/imag...andley/001.jpg https://hosting.photobucket.com/imag...y/001(11).HEIC Plus an under the shell pic https://hosting.photobucket.com/imag...y/001(13).HEIC Then the mod for more droop on the right rear since things get tight in that spot. https://hosting.photobucket.com/imag...y/001(14).HEIC Here’s the double cardan CVDs I put in to combat it spitting out the dogbones. https://hosting.photobucket.com/imag...y/001(32).HEIC https://hosting.photobucket.com/imag...y/001(23).HEIC Also decided to clean up the wiring for now too, may have to rework things a bit if I swap out to a decent motor in the future, what ever that might be. https://hosting.photobucket.com/imag...y/001(33).HEIC https://hosting.photobucket.com/imag...y/001(31).HEIC Routed the battery lead to avoid dragging it on the ground. https://hosting.photobucket.com/imag...y/001(30).HEIC And no, the wires and/or plugs to not drag on the prop shaft either! https://hosting.photobucket.com/imag...y/001(22).HEIC https://hosting.photobucket.com/imag...y/001(20).HEIC Here’s how I trimmed the bumper to clear the front tires at lock, though new posts should help there too. https://hosting.photobucket.com/imag...y/001(27).HEIC Here’s how it looked after finishing today’s work on it.........while watching Wheeler Dealer. https://hosting.photobucket.com/imag...y/001(19).HEIC https://hosting.photobucket.com/imag...y/001(17).HEIC https://hosting.photobucket.com/imag...y/001(16).HEIC |
Re: Tamiya MF-01x Revision I like it! Those portals completely change the gearing, should make a nice difference! |
Re: Tamiya MF-01x Revision I'm waiting patiently for the escort. |
Re: Tamiya MF-01x Revision Quote:
Oh, I just tried to join TamiyaClub and saw you had a thread on there for your Optimus Prime Dynahead on there too! |
Re: Tamiya MF-01x Revision I post here and Tamyia club (when appropriate) - sadly these are the only 2 forums I go to anymore -all the others died off. Quite sad, I can't stand the FB groups - way too many jerks. On my TL, I use a Tamiya Mini motor and a 3:1 reduction. It's just slightly longer than a 540 can and really brings down the gearing. I thought I might be stressing the motor, but it seems to do well as it's within it's RPM range. Great combo, I run these in my CC01's as well, and they barely get warm even over long trail runs. The motors are quite rare though, I managed to snag a few on Ebay - they come up, but not often. https://i.postimg.cc/C1sfBHV9/20200609-163841-SM.jpg On my old Konghead, I used the same reduction unit with a first gen Holmes outrunner. It worked quite well, though it had gobs of torque, it didn't have much wheelspeed. The Dynahead is running a Holmes Crawlmaster 5 slot. One of the higher turns should do pretty good - they run at a bit lower RPM than a regular 3 slot, are super smooth and the torque curve works well with the gearing. Might be a good solution for your build. Can't go wrong for $20! |
Re: Tamiya MF-01x Revision Thanks again8) Sounds like that Torque Master might be the winner then! May even try one for my Telluride trail truck too! After seeming your Dynahead, I kinda want to get one now too, in all seriousness. |
Re: Tamiya MF-01x Revision Was able to order the Monster Beetle TR direct from Tamiya USA for just under $180 (IL sales tax, free shipping!) Once it arrives, the kit bashing can begin:mrgreen: https://www.tamiyausa.com/media/CACH...0733edf71b.jpg |
Re: Tamiya MF-01x Revision Ok folks, the Monster Beetle TR and new M Chassis Bones are in and the kit bashing has begun! https://hosting.photobucket.com/imag.../001(183).HEIC To start, Input an oooollldd Integy 55t from the Wheely King that is getting one of the Holmes 45t motors I got earlier this week and tested it, did much better with the Integy 55t vs that Losi 55t I had in it. https://hosting.photobucket.com/imag.../001(173).HEIC https://hosting.photobucket.com/imag.../001(169).HEIC https://hosting.photobucket.com/imag.../001(179).HEIC Once I got off work I started digging in�� Assembly was pretty much straight forward and simple, I did reuse some of the wheel bearings I put in it 5 years ago https://hosting.photobucket.com/imag.../001(186).HEIC https://hosting.photobucket.com/imag.../001(195).HEIC https://hosting.photobucket.com/imag.../001(185).HEIC Did find some “Hidden Mickeys” in the gearboxes too Here’s how the Right Rear looked once installed with some butchery of the upright extension and adding a spacer between the wheel hub and locknut since the axles it a lot longer! https://hosting.photobucket.com/imag.../001(191).HEIC https://hosting.photobucket.com/imag.../001(193).HEIC https://hosting.photobucket.com/imag.../001(194).HEIC https://hosting.photobucket.com/imag.../001(190).HEIC I then got the Right Front corner on, the wheels just barely clear the screw heads. https://hosting.photobucket.com/imag.../001(196).HEIC And finally, with the body on it for a comparison https://hosting.photobucket.com/imag.../001(189).HEIC https://hosting.photobucket.com/imag.../001(188).HEIC https://hosting.photobucket.com/imag.../001(187).HEIC Then finally, how it looked completed and with a little test driving around the living room! https://hosting.photobucket.com/imag.../001(198).HEIC https://hosting.photobucket.com/imag.../001(197).HEIC |
Re: Tamiya MF-01x Revision Ok, here’s a few pics showing the clearance it has now. https://hosting.photobucket.com/imag.../001(207).HEIC https://hosting.photobucket.com/imag.../001(205).HEIC https://hosting.photobucket.com/imag.../001(204).HEIC https://hosting.photobucket.com/imag.../001(206).HEIC https://hosting.photobucket.com/imag.../001(202).HEIC https://hosting.photobucket.com/imag.../001(203).HEIC https://hosting.photobucket.com/imag.../001(200).HEIC And finally, a pic with my Wheely King that is on the docket for a resurrection as well as was the donor for the Integy 55t and a recipient of one of the Holmes Hobbies 45t 550 motors that came in Tuesday. https://hosting.photobucket.com/imag.../001(199).HEIC |
Re: Tamiya MF-01x Revision Looks great! Adds a lot of clearance and helps with the gear ratio too I'm sure. |
Thanks, BTW! |
Re: Tamiya MF-01x Revision Ran into a small problem when I took a closer look today, the 1.55 wheels drag on then cases and top screws to the point the paint was getting scraped off while driving it once done. https://hosting.photobucket.com/imag.../001(235).HEIC https://hosting.photobucket.com/imag.../001(234).HEIC Same thing up front https://hosting.photobucket.com/imag.../001(234).HEIC https://hosting.photobucket.com/imag.../001(233).HEIC I tried both a set of HPI Vintage NASCAR wheels that I had put the trucks original tires on as well as an old set of Axial 8 hole beadlocks, turns out the HPI’s just clear and the the Axials do Not due to the design for the beadlock ring attachment on the back sides of the wheels. [https://hosting.photobucket.com/imag.../001(232).HEIC URL=https://app.photobucket.com/u/bjoehandley/a/819a4f60-d36e-4e7b-a6c8-a84a8502a153/p/f43c7609-8fc8-4bc3-a99d-a25b90b5e25a]https://hosting.photobucket.com/imag.../001(232).HEIC[/URL] here’s what the final clearance on the HPI wheels are like, they also narrow the track nicely too! https://hosting.photobucket.com/imag.../001(237).HEIC https://hosting.photobucket.com/imag.../001(236).HEIC So..... as of right now, it has a slight.....”skipped leg day” look going until I can get new rolling stock.* https://hosting.photobucket.com/imag.../001(228).HEIC I wouldn’t mind keeping these wheels if I can get the tires off (any advise for how would be appreciated!) and get Proline’s 3.85” tall 1.9 BFG Crawler tires since I would have the tire to fender clearance for those now. |
Re: Tamiya MF-01x Revision I ordered one of the custom 1.9 wheels from Boom Racing to test fit on the truck, should hopefully see it in a couple weeks! Here’s what I went with8) https://hosting.photobucket.com/imag...ley/001(1).PNG |
Re: Tamiya MF-01x Revision Those are some seriously nice wheels! |
Re: Tamiya MF-01x Revision I know, price is decent and I don’t need spend the extra money to get a pair to test out and see if they’ll even on my truck too! |
Re: Tamiya MF-01x Revision Looks great! I was debating doing this same project, very cool that it actually works. |
Re: Tamiya MF-01x Revision Maybe I missed it, but did you get the DCJs work with the portals? |
