05-19-2021, 05:46 AM | #21 |
Rock Stacker Join Date: Jul 2019 Location: USA
| Re: G-Rob's TT-02
I put a Corvette body on mine. I'm a Ford guy but the Mustang's I run against look to be a little top heavy so I went with the Vette.
05-19-2021, 05:48 AM | #22 | |
| Re: G-Rob's TT-02 Quote:
05-21-2021, 09:58 PM | #23 | |
RCC Addict Join Date: Nov 2005 Location: Kansas
These right? https://www.ebay.com/itm/114490355936 Last edited by grob23; 05-21-2021 at 10:02 PM. | |
05-24-2021, 02:59 AM | #24 | |
Rock Crawler Join Date: Jan 2011 Location: Groningen, The Netherlands
The low-friction balls prevent early wear. The front arms dó need replacing eventually, but that’s just how it is. Wear is part of the deal, so to speak. Especially when in competitions. For just street bashing it doesn’t matter too much. Just replace when the balls start popping-out of the a-arms. | |
05-24-2021, 02:05 PM | #25 | |
I'll probably buy a set and have em waiting | |
06-06-2021, 02:34 AM | #26 |
| Re: G-Rob's TT-02
Thanks for that tip. Looks like they are out of stock, I'll check some other sources.
07-04-2021, 11:32 AM | #27 |
| Re: G-Rob's TT-02
After waaaaay to long (procrastination) I got the body finished up. The main color is Tamiya PS-23 Gun Metal Gray. I then backed it with Tamiya PS-5 Black, and then did the windows with Tamiya PS-31 Smoke. Came out OK with just a couple runs. Not bad for only my second lexan paint job With the decals I trimmed a bunch of sponsor logos away for that "stock" look. I like it without a wing, but there's hideous holes already in the body for the wing. Anything I can do to fill em/cover em/ make them less noticeable? I'd also love to find a pair of mirrors that don't look too outta place All I've done to the chassis is add different EBay wheels, and trim the body posts And the car in it's "final" state. This will mostly be a shelf queen I reckon; it's incredibly slow. I do intend to put a different esc in it, and to change up the electronics a bit Questions? Comments? Concerns? Recommendations? Last edited by grob23; 07-04-2021 at 11:35 AM. |
07-14-2021, 06:26 AM | #28 |
| Re: G-Rob's TT-02
Your car looks great, I like the color.
07-14-2021, 02:01 PM | #29 |
| Re: G-Rob's TT-02 |
07-17-2021, 07:47 AM | #30 |
| Re: G-Rob's TT-02 |
07-26-2021, 07:31 AM | #31 |
| Re: G-Rob's TT-02
It’s, indeed, slow with the standard spur. Tamiya gears them very, vèry conservatively. Get Yourself the tt-02 speed gear set from tamiya. It’s not too expensive, and You can fit a far smaller spur that way. That Holmes motor is a crawler/trail motor, so it runs high-torque/low rpm, and the TT-02 just doesn’t have the gearing options to use it efficiently. Even a brushed cheapie 15-turns stock can 540 will be faster in a TC. The TT-01 and TT-02 really like high-revving motors. Anything above about 3000kv under load, will make it come alive. Without them, they’re real slow-pokes, basically only meant for the beginners-class in the Tamiya-Cup races. Oh.. and ditch the plastic shaft in the middle ASAP. It will start to make a hellish rattling ruckus on anything more than a low-rev RS540sh. Aluminium shaft is about $9.- or $10.- Last edited by Jay-Em; 07-26-2021 at 07:38 AM. |
07-27-2021, 05:44 AM | #32 |
| Re: G-Rob's TT-02
I agree, the motor is great for crawling but not for speed. I am using the Tamiya Torque or Sport tuned motors. They're cheap and have decent speed for brushed motors. I use the high speed gear set with a 24 or 25 tooth pinion and the metal drive shaft. I also install ball bearings if I buy the TT-02 standard kits. The R kit has ball bearings included in the kits but the R kits seem to sell out very quickly. Fun stuff. Going to have to buy a star so I can post up some of my cars.
12-05-2021, 03:02 PM | #33 |
| Re: G-Rob's TT-02 |
G-Rob's TT-02 - Similar Threads | ||||
G-Rob's Bronco | grob23 | 1.5 Scale Rigs | 24 | 09-13-2012 04:16 PM |
G-Rob's Yota | grob23 | 1.9 Scale Rigs | 38 | 05-17-2011 05:47 PM |
G-Rob's Axial | grob23 | Axial AX-10 Scorpion | 20 | 06-18-2010 05:25 PM |
G-Rob's ShaftD | grob23 | Tamiya TLT Crawlers | 16 | 11-05-2009 02:48 PM |
G-Rob's Latest | grob23 | Tamiya TLT Crawlers | 14 | 01-19-2009 10:35 PM |
