Go Back   RCCrawler Forums > Regional > Southeast > North Carolina
Thread: dec 7th or 8th gtg?
Old 12-08-2013, 03:37 PM   #21
Here are a couple shots from today's outing.
JKMICK is offline   Reply With Quote
Old 12-08-2013, 03:40 PM   #22
Sorry Laura, tried to get a shot of you as you were coming down, seems just as I took the shot you started to tumble...
Old 12-08-2013, 03:44 PM   #23
Default Re: dec 7th or 8th gtg?
It was fun. Love the last one of your jeep. Apparently I broke my front 3 link.
slim_chance is offline   Reply With Quote
Old 12-08-2013, 04:11 PM   #24
You going to change into 4 link now or rebuild the 3 link?
Old 12-08-2013, 04:15 PM   #25
I'm not sure yet. I might just rebuild the 3 link. I need to tear down the truck and check all the bearings and stuff any way.
Old 12-08-2013, 08:19 PM   #26
Looks like I need to waterproof my ESC on/off switch better. Seems it got wet and did not turn off when moved to the off position. Got everything tore down and cleaned up. Ready for reassembly and further/better water proofing.
Old 12-08-2013, 08:26 PM   #27
I have found that it is 10x easier for me "personally" to just cut it off and tie the 2 wire ends together to complete the circuit. Therefore it is always on and you will never forget to unplug your battery (much more safe when running lipo's especially). If you have some liquid electrical just dunk it in there and problem solved!
wilbywise is offline   Reply With Quote
Old 12-08-2013, 08:47 PM   #28
I just unplug everything. I never use the switch
Old 12-08-2013, 09:38 PM   #29
Great idea! Looks like I'll be bypassing the on/off switch
Old 12-09-2013, 09:38 AM   #30
I worked on the Orange Dingo last night and the steering servo just went bad, there was no water at all inside.
Replacement on order. Until next time!
Scottd9990 is offline   Reply With Quote
Old 12-09-2013, 10:02 AM   #31
Originally Posted by wilbywise View Post
i have found that it is 10x easier for me "personally" to just cut it off and tie the 2 wire ends together to complete the circuit. Therefore it is always on and you will never forget to unplug your battery (much more safe when running lipo's especially). If you have some liquid electrical just dunk it in there and problem solved!
^^^^x2^^^^^^^
hatefulboy is offline   Reply With Quote
dec 7th or 8th gtg? - Similar Threads
going out this weekend? 01/7th or 8th the_ocho Nevada 42 01-09-2012 06:34 PM
FinishLine RC Aug. 6th,7th and 8th rmdesignworks Colorado 20 08-16-2010 09:57 PM
2.2/Scale GTG Aug 7th or Aug 8th crawlinghulls Massachusetts 10 08-08-2010 09:20 AM
2.2/Scale GTG Aug 7th or 8th crawlinghulls Connecticut 9 08-08-2010 03:07 AM
2.2/Scale GTG Aug 7th or Aug 8th crawlinghulls Rhode Island 1 08-06-2010 04:20 AM
