Go Back   RCCrawler Forums > Regional > Midwest > North Dakota
Thread: Truck Pulling!!!!
Old 12-23-2008, 09:57 PM   #1
Default Truck Pulling!!!!
Well I had a ton of fun pulling at WWNH at the last comp, so I thought I would see if anyone else would be interested? Heres what I was thinking for now
TrailTruck Class there would only be 2 restrictions, sled can be hooked no higher than 3inches on the truck and can't have any additonal weight added to the front of the truck. Other than that anything goes.
High Lift Class.
1.Battery 6 cell sub c may not be located any farther forward on chassis than stock location.
2.Axles may be locked.
3.Rear suspension may be locked,Front suspension to be left factory with the exception of after market shocks.
4.Weight-9 LBS all non scale appearing weights must be out of site from normal viewing,Weight boxes permitted.
Weights may not exceed 5 inches from center of front axle forward.
5.Wheelbase and chassis length will remain stock for the H.L chassis.
6.Hitch is to be 2inch max.
The are kinda based of the rcmt high lift pulling class.
thunder7845 is offline   Reply With Quote
Old 12-23-2008, 11:42 PM   #2
im in for sure already started to mod the highlift using the stock front bumper for the weight box mount. started measuring for the hitch too.
sam and i were talking if it goes over well enough we can go off of the rules a little closer but for now just base our rules off of theres.
venom-crawler is offline   Reply With Quote
Old 12-24-2008, 02:37 PM   #3
So no one else is interested or has opinion on this?
Old 12-24-2008, 08:10 PM   #4
did i mention i was in? i know chad and rick are down.
Old 12-24-2008, 08:19 PM   #5
Ok I got ya, so do the rules seem pretty fair?
Old 12-30-2008, 11:44 PM   #6
Well it looks like its just me and you sam that will be pullin the sled.
Old 12-31-2008, 06:48 AM   #7
Eh it's all good, I'm gonna order my highlift next week and the rest for the parts to finish my pro-mod 2wd pullers as well.
Old 01-09-2009, 03:50 PM   #8
Well That does sound like A lot of fun.
Jam1sstang is offline   Reply With Quote
Old 01-09-2009, 11:20 PM   #9
I will be building 3 or 4 pro mod 2wds right off the start, that way I can let people try it and get a little more interest in this type of event. I like crawling but it's nice to throw some other types of events in the mix also.
